HDMI Compatability
So, its been a good while. The question is, has anything been done with any of the OS that has increased HDMI compatibility, or is it still shi%t? The main reason I bought the Pine64 was to use it as a playback device with Plex since it touted its 4k compatibility, and since even a Pi can work with nearly all HDMI devices I expected this to work, but every time I have tried only one Tv/Monitor in my house out of 5 works.
At the moment I'm typing om my pinebook 14" connected to a HDMI screen. Just modified /boot/uEnv.txt file. It works., although the suggested xinerama and clone don't. But outputting to a screen no problem. Just keep in mind the output is YPbPr, so at first I had funny colors, but I adjusted the monitor and now the view is nearliy perfect and very readable.
Erik
Delft.
Ayufan figured out how to add new mode lines to the current table of HDMI modes a while back by working around one of the binary blobs Allwinner left in the video driver. It is still a good bit of work to add more modes to the driver, but basically just someone needs to do it and test them now:
https://github.com/ayufan-pine64/linux-p...965950c9db  Initial support for custom resolutions
https://github.com/ayufan-pine64/linux-p...24c8dd5edb  Automatically calculate ptbl for hdmi bsp driver
(07-06-2017, 10:20 AM)xalius Wrote: Ayufan figured out how to add new mode lines to the current table of HDMI modes a while back by working around one of the binary blobs Allwinner left in the video driver. It is still a good bit of work to add more modes to the driver, but basically just someone needs to do it and test them now:
Thanks for the lead. I was able to get my pine up and running using 720p on the one device I have here in my office using the android 6 image, the screen runs off the edges some. The 7 non tv image didnt work (but may have been my fault for not wiping the card after 6). 7tv version worked with 720p. I am trying 7 again after a full wipe of the card to see if it works this time.
hi rahlquist, its been a long time. Do drop by for a chat at some point.
As for your question, if you are using one of ayufan's android images then you can set one of the supported resolutions in uEnv per his instuctions
In example:
disp_mode=1080p60
I think so.  ทางเข้า sbobet
  lcd touch screen and hdmi output moreaujacky 2 7,637 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 15,648 01-11-2018, 02:52 PM
Last Post: dkebler
  Ongoing HDMI limited compatability rahlquist 39 76,212 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 8,945 04-28-2017, 07:05 AM
Last Post: martinarcher
  Thoughts on eoma-68 compatability? traverseda 4 10,025 02-23-2017, 06:47 AM
Last Post: lkcl
  Switching from touchscreen to HDMI AUDIOTEK 10 19,288 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 9,521 06-10-2016, 04:36 PM
Last Post: shinobi
  HDMI Issue... LeRoms77 4 10,816 04-19-2016, 02:11 AM
Last Post: LeRoms77
  nexdock (laptop style HDMI display w/ BT keyboard/touchpad) neoaeon 5 12,084 03-10-2016, 07:43 PM
Last Post: hrh1818
