Gigabit Ethernet performance testing
For documenting the performance of the Gigabit ethernet onboard the Rock64.
If you want to post your own results, remember to mention which board you are using (1/2/4GB), OS/kernel, and any relevant software or hardware changes you have made.
Most testing will be done using iperf3 (sudo apt-get install iperf3), but other benchmarking methods are welcome.
Also do not forget to set the performance CPU governor (must do through sudo -i or sudo tee). (echo performance >/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor)
Linux rock64 4.4.70-ayufan-44 #1 SMP Fri Jun 30 23:23:09 UTC 2017 aarch64 GNU/Linux
(ayufan rock64-linux-build 0.2.5, Debian Jessie minimal)
Rock64 2GB
iperf3 3.0.7
Remote host is a Lenovo Thinkcentre with RTL8111/8168/8411 ethernet.
Rock64 (client) --> Thinkcentre (server)
[ 4] local 192.168.0.120 port 49148 connected to 192.168.0.85 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 104 MBytes 868 Mbits/sec 0 2.39 MBytes [ 4] 1.00-2.00 sec 108 MBytes 904 Mbits/sec 0 2.39 MBytes [ 4] 2.00-3.00 sec 108 MBytes 902 Mbits/sec 0 2.67 MBytes [ 4] 3.00-4.00 sec 108 MBytes 902 Mbits/sec 0 2.67 MBytes [ 4] 4.00-5.00 sec 105 MBytes 880 Mbits/sec 0 3.63 MBytes [ 4] 5.00-6.00 sec 110 MBytes 921 Mbits/sec 0 3.63 MBytes [ 4] 6.00-7.00 sec 105 MBytes 883 Mbits/sec 0 3.63 MBytes [ 4] 7.00-8.00 sec 110 MBytes 923 Mbits/sec 0 3.63 MBytes [ 4] 8.00-9.00 sec 106 MBytes 891 Mbits/sec 0 5.45 MBytes [ 4] 9.00-10.00 sec 106 MBytes 891 Mbits/sec 0 5.45 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.04 GBytes 896 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec receiver iperf Done.
Thinkcentre (client) --> Rock64 (server)
[ 4] local 192.168.0.85 port 54468 connected to 192.168.0.120 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 111 MBytes 931 Mbits/sec 0 450 KBytes [ 4] 1.00-2.00 sec 112 MBytes 941 Mbits/sec 0 474 KBytes [ 4] 2.00-3.00 sec 112 MBytes 937 Mbits/sec 0 474 KBytes [ 4] 3.00-4.00 sec 111 MBytes 929 Mbits/sec 0 474 KBytes [ 4] 4.00-5.00 sec 112 MBytes 940 Mbits/sec 0 474 KBytes [ 4] 5.00-6.00 sec 111 MBytes 933 Mbits/sec 0 474 KBytes [ 4] 6.00-7.00 sec 112 MBytes 938 Mbits/sec 0 474 KBytes [ 4] 7.00-8.00 sec 112 MBytes 942 Mbits/sec 0 474 KBytes [ 4] 8.00-9.00 sec 112 MBytes 936 Mbits/sec 0 474 KBytes [ 4] 9.00-10.00 sec 112 MBytes 936 Mbits/sec 0 474 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.09 GBytes 936 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver iperf Done.
  on-board ethernet driver michaelanburaj 0 3,405 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  Ethernet latency nethammer 1 4,682 10-17-2019, 05:15 PM
Last Post: nethammer
  ayufan 0.7.12 pre-release images (help testing) Luke 1 6,782 03-22-2019, 05:11 PM
Last Post: Luke
  Gigabit Ethernet problems aaronw 2 9,002 02-16-2019, 03:04 AM
Last Post: uttam
  testing latest ayufan u-boot (2017.09-rockchip-ayufan-1035-gd646df03ac) jandastroy 1 5,093 12-24-2018, 08:58 PM
  Running debian testing, web video blows :( dougunder 2 6,385 04-22-2018, 03:24 PM
Last Post: dougunder
Sad Rock64 4GB poor USB3 HDD performance KernelPanic 7 21,344 04-11-2018, 02:20 AM
Last Post: KernelPanic
  USB3 performance tests pfeerick 12 28,197 03-17-2018, 09:35 AM
Last Post: pedroz
  Stock debian image - rock64 - gigabit rhille 11 22,462 08-29-2017, 07:48 AM
Last Post: rhille
  Broken yellow Ethernet light? jl_678 1 5,550 08-27-2017, 04:23 PM
Last Post: MarkHaysHarris777
