Left vs Right USB socket on Pinebook 14"
Just wanted to comment that I noticed that a USB HDD plugged into the LEFT USB port won't power up properly (looks like it can't get enough current), but plugged into the RIGHT USB socket it behaves normally.
Is this intentional?
It's not a problem as you can use the right hand socket but it is an inconvenience if you are not aware of it.
AK
Not sure but I noticed that if I use the left USB to try to charge a device, at least in Android, it crashes repeatedly, presumably because the power out is screwing with the power supply/controller. haven't tried the right USB for that, only for a mouse.
it doesn't get happy
it doesn't get sad
it just runs programs
Keep in mind that all the ports are limited to 500mA as per the USB spec. So running any harddrives or other things that need more than 500mA is more a game of luck and probably causes instability issues...
The left socket is a USB-OTG port, and not a 'normal' USB host port. That's why it behaves strangely.
The right port is a full USB root port.
  Running Pinebook (non-Pro) without battery? guidol 0 355 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 10,525 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 5,003 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,005 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 2,861 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 2,773 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 3,999 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 6,238 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 4,739 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 5,712 01-13-2021, 11:03 AM
Last Post: barray
