4K Media Package Enclosure
Not sure if this has been answered anywhere, but is the acrylic case with the 4 pegs/supports the one that is included with the 4K Media package? This is what is says for my pledge:
Items included in your pledge
$59 Reward
The PINE A64+ 4K Media Computer You will get the PINE A64+ 1GB unit along with 8GB MicroSD Pre-Loaded with Android 5.1. IR receiver and remote control, PINE64 Power Supply, and the PINE64 Enclosure. You can upgrade to a 2GB model later for $10. (Light Assembly Required) (No wifi/bluetooth - we will offer a list of compatible wifi/bluetooth modules you can use to connect later).
As you can see, it doesn't specify which case is included.
(02-17-2016, 11:22 PM)Inuyasha Wrote: Not sure if this has been answered anywhere, but is the acrylic case with the 4 pegs/supports the one that is included with the 4K Media package? This is what is says for my pledge:
$59 Reward
Awesome! That's the one I was hoping it would be. Thanks, tllim!
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,682 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,502 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,526 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,910 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,919 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,170 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,142 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 31,605 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,630 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 10,494 10-13-2016, 08:47 AM
Last Post: Bluphire
