(02-17-2016, 10:43 AM)Gearsoul Wrote: Oh! Actually I haven't seen the news for them, but I buy from Geek(Wish re-skin) and a few times now I've seen comments/feedback left about things catching on fire! =0c
Size, according to a quick google: "Measures approximately 4" x 2" x 5" when closed"
As to vents.... There's a small vent on the back? Perhaps I could sand the battery compartment smooth and then carve/drill a larger vent in a suited style into it?
(Photo)
I've just realised what you mean by hover boards.... Those things have WHEELS and they should never have been allowed to call them hover boards! 'XD
Oh, I should point out the battery compartment visible in that photo is actually the much smaller backup battery compartment! I was referring to the main one, which is about four times the size.
This case would be for the handheld, rather than the PlayBox unit. Just a little 'bare bones' version to read on, though fitting in a speaker -- which is actually what that thing I presumed was a vent is? -- would be awesome.
If I slip the pine board in, carve out a hole for the screen, what else do I need to include? Well, as it's the handheld, it'll need a battery. Maybe forego the speaker in favour of a headphone jack to keep as much room in there for them to breathe?
You're right - those things are not true hoverboards at all!
As for the Harry Potter case, it might juuust about be big enough, though the longest part of the Pine is slightly over 5 inches, so you may struggle to get it all in there. The two inches height and four inches width should be more than enough, however.
What you'll need for a handheld? Do you basically mean a custom tablet style thing, or a gaming handheld?
But yes, you'll need a battery and a screen at least.
