Phoenix Card and Norton Security don't mix . . .
To share an experience.  Norton Security decided to flag parts of Phoenix Card as being on their naughty list.  No Santa for them.
Naturally disabling parts of the software tends to cause behavioral issues.  UpdateVer.exe and ParserManager.dll are targeted for attention based upon a bad reputation heuristic.  They both need to be in place for the program to work.  I was seeing "script not found" errors when using a perfectly good Phoenix image.  A reinstall and slapping Norton's hand when it tried to zap the files solved the problems.
Now I've got the image burned, I'm still waiting for the silly thing to boot.  Rolleyes
Best Regards,
Matthew
The Script Not Found error usually occurs due to trying to burn a DD image using PhoenixCard, rather than the appropriate PhoenixCard image.
Let us know how it goes.
(08-16-2016, 06:55 AM)Ghost Wrote: The Script Not Found error usually occurs due to trying to burn a DD image using PhoenixCard, rather than the appropriate PhoenixCard image.
Understood.  If I had used the wrong image . . . it wouldn't have burned.  I have verified this previously through experiment.   Cool
It's up but seems kinda slow and laggy and it's rolled a bunch of times.  It's a 2GB unit.  Maybe I'm expecting too much or should give up and pick a different OS.
Thanks,
Matthew
Thanks,
Matthew
Experiment some more and try a different OS, see where you stand after that. Which OS is it that you burned?
Thanks,
Matthew
Burned the latest Android Build.  android-ver5.1.1-20160711-pine64-phoenixCard
Going to pick a Linux distro and see what happens.
Thanks!
Matthew
Check out our irc chat site; we help lots of people get going with PineA64. Sometimes its just easier to work things out on-line live in chat... just an idea.
  How to boot from SD card on pinebook pro linux123 3 9,287 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 6,318 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 6,449 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 9,209 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 275,843 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 17,059 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 14,419 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 5,461 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 5,430 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 34,258 09-22-2016, 06:28 AM
Last Post: tkaiser
Users browsing this thread:
