(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
(07-21-2016, 04:36 PM)kermitas Wrote:
(07-21-2016, 01:57 PM)hhbarnes Wrote: I've got a problem I hope someone can help me out with.
Over the weekend I successfully installed the latest build on 4 of my new Pine64+ with 2GB and they were working great. My intent is to run these as headless servers so I restarted them without the HDMI cable. Unfortunately every one of the boards stalled during the reboot and wouldn't come online. When I plugged the cable back in each started up without issue.
I'm a bit of a noob in this are and am still learning the ropes so please bear with me. Do I need to add an entry into the uenv.txt file to allow the board to ignore the missing HDMI cable during the initial boot or is there something else going on?
Thanks,
Harry
My Pines boot with and without HDMI cable.
Awesome, unfortunately all four of mine don't. With that said, I do have a fifth one built with the OpenHab image that boots fine without HDMI. It looks like that is based off this image.
Sent from my iPhone using Tapatalk
Thanks,
Harry
Check your router page and see if the Pines that you have shows up in the list of devices that is connected to the router, if it shows up, your Pines are working perfectly, you just need to set up ssh on your Pines to access them.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
Thanks,
Harry
They don't. The Ethernet plug never links up with the switch and the activity indicators never begin blinking.
Can you hop onto the IRC chat? Maybe we can figure out your problem there...
(07-25-2016, 05:28 AM)xalius Wrote: Can you hop onto the IRC chat? Maybe we can figure out your problem there...
Can't right now, but I can jump on later tonight.
(02-28-2016, 03:07 PM)longsleep Wrote: I also built a mimimal Ubuntu image combined with the the BSP Kernel and my image building gear. Similar to the Arch Image **this image is intended for developers. If you are looking for accelerated 2D/3D or video decoding use Android** and do not bother with trying this image.
What you get:
- HDMI at 1080P
- HDMI analog audio (alsa, pulseaudio)
- Ethernet (including 1000M)
- USB
- Wifi
- Ubuntu Ubuntu 16.04 (Xenial Xerus) aarch64
- BSP Linux Kernel 3.10.65+ (see http://forum.pine64.org/showthread.php?tid=293)
- BSP U-Boot (see http://forum.pine64.org/showthread.php?tid=99)
- Support for all Pine64 models (512MB, 1GB, 2GB) with auto detection so Ethernet works with the same image on all models
It works good enough so it can be used as headless server, as compile platform for aarch64 or as virtualization host. You can even install a desktop environment if you wish.
These images require a 4GB medium (3700 MiB rootfs). Extend the partition with `sudo /usr/local/sbin/resize_rootfs`.
Download (for instructions see README.txt)
Starting with Kernel 3.10.101 it is possible to lower HDMI resolution from 1080p to 720p. See http://forum.pine64.org/showthread.php?tid=980 for instructions.
History:
**20160228-2**
- Initial publish release
- Known issue: console-setup.service fails to start
- Firefox is very unstable
**20160306-1**
- Updated U-Boot and device tree to 20160306-1
- Updated Kernel to 3.10.65-2-pine64-longsleep-39-1
- Ethernet MAC address is now persistent (added to uEnv.txt on first boot)
- Added system service to reenable CPU cores
- Added helper Pine64 platform scripts to /usr/local/sbin
- Serial getty no longer waits on rc.local service
- Linux Kernel firmware and headers are now installed
**20160320-1**
- Added support for Pine64 512MB model (auto detected)
- Updated U-Boot and device trees to 20160319-1 (2014.07-3-pine64-longsleep)
- Updated Kernel to 3.10.65-3-pine64-longsleep-2
- Wireless tools are now installed by default (iw, rfkill, wpasupplicant)
**20160403-1**
- Updated Kernel to 3.10.65-4-pine64-longsleep-16 (fixing Pine64+ 2GB model Ethernet crash)
**20160424-1**
- Updated U-Boot and device trees to 20160423-1 (v2014.07-4-pine64-longsleep)
- Updated to Kernel 3.10.65-7-pine64-longsleep-28
- Initrd updated to support root= Kernel parameter and wait for rootfs delay (thanks to j0zzy)
- Ubuntu rootfs updated to 16.04 Xenial Xerus final release
- Platform scripts were updated to latest
- Mackeeper service was updated (thanks to sWski)
- UART2, UART3 and UART4 are now enabled (thanks to Martin Ayotte)
**20160507-1**
- Updated to Kernel 3.10.101-0-pine64-longsleep-39
- Alsa-utils are now installed by default, including sane mixer settings
- It is now possible to change the HDMI resolution via uEnv.txt (sunxi-disp-tool installed by default)
- Default hostname is now "pine64"
- Locale en_US.UTF-8 is now pre-generated
**20160716-1**
- Updated to Kernel 3.10.102-2-pine64-longsleep-66
Released images are signed with a detached GPG signature (.asc) signed by my personal key 0x090EF0DB. Get the key and verify that the download is intact and unmodified.
gpg --keyserver keyserver.ubuntu.com --recv-keys 090EF0DB
gpg --with-fingerprint xenial-pine64-*.xz.asc
Let me know what you think.
Hello. Witch repository use this distro? How can i add new repository? I cant find those package: nginx, mysql...
It is a normal Ubuntu Xenial release, so you can use any guides for adding repos you find for Ubuntu. As for the availability of packages, not all packages are built or work on the ARM64 architecure (arm64, aarch64). There was not a lot of hardware around yet for distros to test their packages on but that should improve now that the Pine and other arm64 SBCs appear on the market. You can run 32bit (armhf) binaries on your Ubuntu if you install multiarch support, but it is not always easy to do, since you need to install every single dependency of a package in the matching architecture as well, and sometimes things break.
I have successfully installed nginx with regular apt-get... with no extra repositories.
Sorry, but I have to ask, have you tried to run sudo apt-get update ?
(07-29-2016, 08:30 AM)pekapa Wrote: I have successfully installed nginx with regular apt-get... with no extra repositories.
Yes of course! Please write packet name that you install...
sudo apt-get install nginx
FYI, here is my source file as well:
/etc/apt/sources.list
deb http://ports.ubuntu.com/ xenial main restricted universe multiverse
deb-src http://ports.ubuntu.com/ xenial main restricted universe multiverse
deb http://ports.ubuntu.com/ xenial-updates main restricted universe multiverse
deb-src http://ports.ubuntu.com/ xenial-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ xenial-security main restricted universe multiverse
deb-src http://ports.ubuntu.com/ xenial-security main restricted universe multiverse
deb http://ports.ubuntu.com/ xenial-backports main restricted universe multiverse
deb-src http://ports.ubuntu.com/ xenial-backports main restricted universe multiverse
  Ubuntu server 20.04 request phi0x 2 11,148 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,607 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,008 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,611 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,549 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,769 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,381 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,872 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,721 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,628 08-23-2017, 09:28 AM
Last Post: gilbertotcc
