ssh into Pine64 running Android
I can easily ssh into my Pine64 running Ubuntu, but I'm going around in circles trying to figure out how to do it under Android.
Is there a HOWTO anywhere?
Being able to ssh into Android is contrary to the design principles of Android.
... that said, it has always been possible to ssh into an Android phone; first by rooting it, and second by placing an sshd (ssh daemon) on the device like dropbear, or similar. Android was designed to have a locked-down linux kernel, and a java virtual machine layer over that (Dalvik) to run apps. It was not designed to work like a standard gnu+linux computer (although with rooting, dropbear, and busybox it can be made to work like any other gnu+linux device).
I would recommend you experiment with the rooted android image; then check out 'dropbear' and 'busybox'.
There are many on-line resources available to help in this area, and there is a huge droid community to help as well.
marcushh777
It is possible to use the rooted image, and an sshd server like 'dropbear' for android, as well the 'busybox' suiteof gnu+linux like tools.
Experiment with the rooted android image.  Also, find 'dropbear' on the Play Store, as well the 'busybox'.
marcushh777
Shy
I have posted to this topic twice... they have vanished... not sure where the posts are.
marcus
(07-24-2016, 08:58 PM)scarabus Wrote: I can easily ssh into my Pine64 running Ubuntu, but I'm going around in circles trying to figure out how to do it under Android.
You will need root and a 3rd parts SSH server Installed as android used adb as default
Or check out "Termux" if you don't want to roo the PINE64
  Need help compiling android for pine a64 + YeeticusMaximus22 1 518 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 543,159 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 43,697 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 27,790 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 10,999 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,255 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,058 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,746 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 362,382 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,469 02-26-2019, 11:58 AM
Last Post: Twistedx
