Compiling kernel for Android?
Has anyone managed to build a fully working kernel for Android? And how?
I need to enable some extra drivers for my hardware. I've got a kernel built that boots, but only the top USB port is functional.
Source I'm using: https://github.com/longsleep/linux-pine6...2-0-pine64
From SDK i think is a easy way. You download this from wiki of pine
(07-11-2016, 01:05 PM)kap1r0t0 Wrote: From SDK i think is a easy way. You download this from wiki of pine
but there's no kernel source in it, only a pre-compiled kernel image
I found this link on web
http://www.murlock.org/a64/lichee_A64_A5.1_V1.0.tar.gz
The BSP 2.0 package contains kernel source code. I'd apply longsleep patches overtop of the BSP as there are google patches specific to android that won't be in the longsleep kernel (unless it already contains them) and potentially other android specifics as well as the device tree which are not present for the binary blobs (if you were to build the whole android image)
EDIT:
look here http://linux-sunxi.org/SDK_build_howto
Backer #6878
shipment status: arrived
Kernel from BSP is even less functional. A while after showing the Android splash screen, it just reboots.
I'm guessing my USB issue is related to the DTBs being missing. I can't figure out how to build the dt.img for PINE.. and the original Android kernel doesn't contain a dt.img or any DTBs in the ramdisk or /system.
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,531 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 575,447 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 46,910 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 29,955 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,785 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,139 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,768 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,203 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 388,968 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,937 02-26-2019, 11:58 AM
Last Post: Twistedx
