temporary enclosure with lcd
has anyone created a decent "enclosure" for their pine64 that includes the lcd?
what did you do?
how did you orient the PCB in regards to the panel, so that the cables reach nicely?
what was it made of?
did you get the camera in there somehow?
other addons?
i'm thinking about getting some lexan (i have a sheet around here somewhere) and try to put something together so that i can at least hold the thing like a tablet, until my actual enclosure arrives (via the original kickstarter).
I found an enclosure at the Verizon wireless store (designed for their tablet|phone). I am investigation whether the PineA64 guts & LCD may be enclosed in their cab.
keep you posted
marcus
I had one made for me in acrylic using a laser cutter. It is NOT perfect, and I do not have the files to post here. It was done use tongue and groove joints, with acrylic glue. The top panel has some screws so I can easily get it out if needs be. Also I 3d printed one of the cases i found on thingverse which is where the pine is store INSIDE the acrylic case. Attached are some pictures.
[Image: enclosure.jpg]
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,952 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,983 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,624 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 13,024 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 10,025 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,316 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,323 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 31,844 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,778 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 10,593 10-13-2016, 08:47 AM
Last Post: Bluphire
