recommended micro sd card ?
#81
Thanks.
Very helpful again.
At first I thought that the constraint might be the Pine's 2.0 USB controller but if the random write performance from pine sd card to usb stick went down while the random read performance from Pine sd card to USB stick went up it doesn't seem that the Pine's 2.0 USB controller is what is limiting usb random write performance..
#82
Using an Intergral 64GB USB 3.0:
Run began: Fri Jul 1 21:01:52 2016
Include fsync in write timing
O_DIRECT feature enabled
Auto Mode
File size set to 102400 kB
Record Size 4 kB
Record Size 16 kB
Record Size 512 kB
Record Size 1024 kB
Record Size 16384 kB
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 kBytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
102400 4 1816 1668 5914 4980 5395 929
102400 16 5987 6767 18200 17952 17514 3320
102400 512 16531 17967 32526 33244 32805 12625
102400 1024 14803 19849 35492 36330 36312 14429
102400 16384 13931 11563 37908 37925 37153 14658
iozone test complete.
#83
Thanks JamesRead90.
More data is always better!
So for random writes it looks like your Intergral 64GB USB 3.0 is faster (14,658 kBytes/sec) than the Pine64 SD card (11,300 kBytes/sec).
#84
Xalius, how do these results stack up against the Pine64 card and my Integral 64GB USB 3.0? For this test I used my Kingston Datatraveler Ultimate USB 3.0.
Run began: Thu Jul  7 00:48:48 2016
Auto Mode
Record Size 4 kB
Record Size 16 kB
Record Size 512 kB
Record Size 1024 kB
                                                             random    random     bkwd    record    stride                                                  kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread          102400       4     5965     6589    10653    10657     7472      349        102400      16    12626    12643    21321    21292    21200     1274        102400     512    16669    13970    38586    38322    38251      807        102400    1024    12490    12473    39157    39186    39121     1589        102400   16384    26150    29875    41209    41221    41218    19738
#85
So for random writes and ranked in order of speed from fastest to slowest:
1) Samsung EVO 64 GB xalius 21,690 kB/sec
2) Integral 64GB USB 3.0 Jamesread90 (2nd test) 19,738 kBytes/sec (Kingston Data traveler Ultimate USB 3.0)
3) Sony USB 64 GB USB 3.0 xalius 12,157 kB/sec
4) Integral 64GB USB 3.0 Jamesread90 14,658 kB/sec
5) Pine64 SD card xalius (11,373 kBytes/sec).
This ignores cost of each option.
Jamesread 90 what is the difference between your results in #2 and #4?
#86
Testing Linux pine64 4.7.0-rc1firebuild-MMC #1 SMP PREEMPT Sun Jul 24 11:56:29 CDT 2016 aarch64 GNU/Linux
debian@pine64:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Sun Jul 24 17:19:09 2016 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 1610 2793 5949 5955 5940 2852 102400 16 7435 7585 9155 9176 9175 7645 102400 512 11091 11199 11644 11624 11633 11122 102400 1024 11205 11258 11668 11651 11664 11264 102400 16384 11045 11297 11684 11681 11685 11304 iozone test complete.
For comparison with the latest BSP 3.10.x kernel (102-2):
ubuntu@pine64:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Run began: Sat Jun 18 11:29:59 2016 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 2319 3321 7347 7363 7357 3526 102400 16 10166 12550 14464 14432 14471 12570 102400 512 21591 21566 23143 23140 23139 21616 102400 1024 21653 21565 23097 23100 23098 21645 102400 16384 21678 21662 23084 23082 23082 21690 iozone test complete
#87
New data from Pinebook eMMC for comparison, running with performance governor on Linux pinebook 3.10.105-bsp-1.2-ayufan-65 #1 SMP PREEMPT Mon Jun 5 06:57:47 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
Run began: Sat Jun 17 19:12:37 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.                                                              random    random                                                  kB  reclen    write  rewrite    read    reread    read     write          102400       4     4078     4211    19836    19561    13048     3360        102400      16    18230    18891    50913    51223    37699    14025        102400     512    55205    54522    84858    84813    83709    49719        102400    1024    55929    55135    84625    85749    85235    51696        102400   16384    56507    56041    85515    85579    85930    55151
#88
pine64@pinebook:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O        Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux  Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins             Al Slater, Scott Rhine, Mike Wisner, Ken Goss             Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,             Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,             Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,             Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,             Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,             Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Wed Jun 21 23:09:02 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.                                                               random    random     bkwd    record    stride                                                   kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread           102400       4     3018     3096     8644     8631     8167     3715        102400      16     8248     8363    16757    16863    16571     9702        102400     512    21553    21338    23032    22853    22827    20587        102400    1024    21358    21313    22921    23142    22855    21118        102400   16384    21168    21375    22947    22915    23134    21070                                                           iozone test complete.
Forgot to mention that this is one of the new Sandisk A1 32 gig card.
#89
Sandisk Extreme Pro 32GB with A1 / V30 rating
pine64@pinebook:/media/pine64/6532-6630$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O        Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins             Al Slater, Scott Rhine, Mike Wisner, Ken Goss             Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,             Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,             Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,             Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,             Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,             Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Fri Jun 23 18:28:17 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.                                                              random    random                          kB  reclen    write  rewrite    read    reread    read     write            102400       4     3420     3442     7736     8133     7404     4750        102400      16     7509     8154    15160    15040    14810    10800        102400     512    17752    21726    22651    22747    22798    20674        102400    1024    17836    21356    22843    22907    22877    20994        102400  16384l    18359    22042    23038    23038    23093    21774
#90
(01-24-2016, 06:10 PM)mronhb Wrote: please excuse the noob question but can anyone please recommend a good brand and class of micro sd card to buy to use with the PINE A64+ w/ 2GB SDRAM. I am very excited about receiving mine in March but very much wanting advice on the best micro sd card to buy. Any advice greatfully accepted thanks  Smile
Hello
The choice of sdcard is rather important, sd cards suffer from a symptom called 'Wear Level', this where cards that are constantly being written over and over again such as dashcams or video camera cards, suffer premature failure due to data blocks within the memory stack being corrupted and not accepting any more data. The blocks are tagged in the VTOC (Volume Table of Contents) and the 32gb sdcard is no longer 32gb, The Samsung line of SDcards (extreme usage) though a little more expensive seem to hold up the best when benchmarked, it is very important that the card is specified for high read/write (sometimes you may see a card specified for video for example) and the phrase the phrase Extreme Usage' should be displayed in the item description, this information is well known to the SD card manufacturers and is just now making its way into general parlance.
  Recommended kits to buy? Silk 1 5,853 12-06-2020, 11:28 PM
  How to boot from SD card on pinebook pro linux123 3 10,457 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,196 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,262 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,409 03-18-2020, 09:42 AM
  eMMC card on adapter Malmgren 8 19,068 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,266 02-08-2017, 05:42 PM
Last Post: maxpayne
  unable to write an pine64 image on a 16G micro suresh 2 8,721 01-26-2017, 12:56 PM
Last Post: suresh
  recommended micro sd card? Gustavo Woltmann 1 6,195 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,174 11-03-2016, 02:33 PM
