New keyboard issue
#31
(10-05-2023, 02:27 AM)grump_fiddle_reinstall Wrote:
(09-02-2023, 10:24 AM)grump_fiddle_reinstall Wrote: I just remembered that I still have the default Manjaro image installed on the eMMC on my PPPro still. I will boot into that sometime with the PPPro in the keyboard case to see if the keyboard works under Manjaro.
Finally got round to testing this. The keyboard does not work under Manjaro on my PPPRo either, which suggests a hardware fault with the keyboard.
I bought and fitted a new keyboard circuit board.
The keys still do not work although the PinePhone is charging from the keyboard battery. So I assume that this is not a hardware issue as this was the situation with the previous circuit board installed.
I checked if the driver was installed and there is no sign of kb151 on my mobian install. I appear to be running bookworm.
Has the driver been removed from the kernel? The version on my PinePhone according to Synaptic up to date and is 5.15.10+sunxi64-5.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,220 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,277 12-23-2025, 04:25 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,470 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 5,987 01-14-2025, 02:49 AM
  Keyboard not popping up on QT apps 3x5co 1 3,370 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 3,081 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,891 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,194 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,689 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 8,095 11-28-2022, 10:58 AM
Last Post: 3x5co
