eSIM on PinePhone
Hey all,
Are multiple eSIMs support on the Pine Phone?
Thanks.
There is no eSIM on the PinePhone.
anyone tried or asked about PinePhone support with https://esim.me/
I would clarify if the modem supports eSIM first
eSIM.me is an Android application and as such will not work on the PinePhone. (I strongly doubt that it can be made to work in a virtualized environment such as Waydroid. It probably will not even work under native GloDroid because the app also needs to support the specific hardware.)
You will need a physical SIM card. (And keep in mind that the PinePhone can only accept one SIM card at a time. Using multiple ones requires opening up the phone to physically swap the card.)
An update on this topic:
There is now an eSIM manager for mobile GNU/Linux: https://linuxphoneapps.org/apps/eu.lucaweiss.lpa_gtk/
Since the PinePhone does not have eSIM support built in, using this on the PinePhone requires a physical "eSIM card", i.e., a physical SIM card which accepts eSIM downloads. The ones from eSIM.me are such, but do note that the eSIM.me terms of service prohibit using their cards with anything other than their proprietary Android application. So use at your own risk. There are other providers, such as 5ber or sysmocom, who may have friendlier terms of service. Though of course none will officially support third-party applications. At best they will not try to actively ban them through licensing and/or technical measures.
Once you have that, you should be able to get the app to work on your PinePhone by setting some environment variables: https://fosstodon.org/@z3ntu/112673191458149259
Be warned that I have not tested any of this and that so far I am not aware of anybody having tested it yet.
i sort of like physical sims. nano-sim seems to be good size at the moment.
however, esim inside of physical sim might to be good idea. i probably need to think about it this in the future. i noticed that some operators charge for every activation of esim. which i think it is not a good idea, unless user excessively activates it.
(07-02-2024, 01:30 AM)zetabeta Wrote: i sort of like physical sims. nano-sim seems to be good size at the moment.
https://fosstodon.org/@linmob/112673250227986590
https://codeberg.org/lucaweiss/lpa-gtk
It looks promising. Has anyone actually tried lpac, lpa+gtk on the PinePhone?
i shall test on some timetable, and i report back. however, i don't have e-sim on from any operator.
i don't pretend to know everything, only some.
short version is: pinephone does not have esim storage, both pp regular and pp pro.
i ended up to this website https://github.com/estkme-group/lpac . and i used this command line tool in debug mode, debug was limited, but it manage to communicate with eg25 modem chip. eg25 has esim support but no internal esim chip, and also no esim chip on pinephone mainboard.
esim might be possible inside physical sim card. but i don't have one to test. theoretically it should work.
i didn't get graphical program to work well.
  How can I record video on a Pinephone? kk22 23 18,570 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 5,733 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 6,169 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 606 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 3,623 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,064 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 871 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 5,566 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 2,145 10-06-2025, 09:05 PM
  iso pinephone for sale (USA) elwoodb25 0 4,224 09-24-2025, 09:25 PM
Last Post: elwoodb25
