various tricks to open the pinephone
What are the various tricks you have to open the pinephone?
In specific, to separate the back cover from the front "brick"
a crack.  [Once I get started, the rest is easy.]
I used to be able to open it.  I have not opened it for over
4 months, so dust, etc, probably settle inside.
The methods I am aware of
1.
Hold the phone upside down, facing your heart.  Put your
right fingernail in the slot and pull toward your right
shoulder.
2.
Hold the phone upside down, facing your heart.  Put a
credit card in the slot and zip right, pulling alittle.
3.
Turn the phone upside down and over, facing desk.  Put
a credit card in the slot.  Slide leftward and pull.
i
Are there any way to clean the slot with the cover on?  I
tried rubbing alcohol and q-tip.
Thank in advanced for any help.
Sheng-Chieh
I finally got the pinphone opened.  Yay!  What a pain in the neck.
Needed to since I got a power problem, but don't worry about this -
I start a new post if needed.
What I did is use a screwdriver where the tip is about the same
thickness as the slot.  Push down, alittle to the right, and pry
it opened.  I do >>> NOT <<< recommend this unless you are desparate
to open the pinephone since you will dent the slot.  I.e. try the
3 methods in the OP first.
Now the issue is how to make it easier to open the pinephone again
and again and again.  Beside the slot, there is plastic "pins" about
1/2" from the slot on the back cover and there is a "hole" about
1/2" from the slot on the front part.
I already
1. cleaned the "pins", "hole, and slot.
2. filed the "pins" a tiny weeny bit (still want cover to snap on).
Any other suggestion?  Will lubrication on plastic work?  Will
removing some "pins" help?  If so, which one?
Thank in advanced for any help/tip.
Sheng-Chieh
my pinephone is really easy to open, but that is because I had to take the battery out whenever it froze. the more you open it the easier it gets to take off the back. mine opens sometimes when I'm just trying to take the case off lol
Go to a music store and buy a package of guitar picks, these are great tools for popping-open most snap-shut electronics.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,427 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,410 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,822 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,759 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,244 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,874 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,842 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,471 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,557 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,065 03-25-2025, 08:51 PM
