Faulty lcd screen? Wrong install process? Help!
I have tried many times to instal different android builds to work with my pine and the pine touch screen I have, and none have worked or even booted up. I installed linux to make sure it wasn't the pine it self, but I was able to boot into and have full functionality. Am I going around the android process wrong? Or is my lcd touch screen faulty? I am using a mac and have downloaded the DD root image for a 64 gb card, and DD to the card, then plug the card into my pine with the lcd touchscreen attached.
(06-12-2016, 01:05 PM)Krinilssen Wrote: I have tried many times to instal different android builds to work with my pine and the pine touch screen I have, and none have worked or even booted up. I installed linux to make sure it wasn't the pine it self, but I was able to boot into and have full functionality. Am I going around the android process wrong? Or is my lcd touch screen faulty? I am using a mac and have downloaded the DD root image for a 64 gb card, and DD to the card, then plug the card into my pine with the lcd touchscreen attached.
Hmm. I assume you downloaded and burned one of the Android images specifically designed for the Pine LCD touchscreen?
Yup it was this one: Android 5.1.1 Image (LCD Panel Video Output) Release 20160603
With the rooted DD image: For 64GB microSD Card
All I did was download and extract the .img from the rooted DD image. Then I DD'ed the image to the 64gb card I have. When it finished, which took over night, I unplugged it and plugged it into my pine, with the lcd panel attached and then plugged in the power.
Did you also try the 32GB image? Some people have reported the file size of the DD images as being ever so slightly too big for their microSD cards, depending on brand (perhaps some brands have a different way of reporting storage space to their host?)
Not sure why it is taking so long to burn, either. It shouldn't take all night.
Something is not right there.
Did you get any sign of life from the LCD? Mine was flickering white due to poorly connected cables.
  screen rotating Miguelito71 0 4,677 07-29-2019, 12:48 AM
Last Post: Miguelito71
  Youtube TV experience/ screen resolution issues gubaguba 0 3,153 02-22-2018, 09:12 AM
Last Post: gubaguba
  Android 6.0 How to turn the screen back on modsbyus 4 8,540 11-28-2017, 01:03 PM
Last Post: modsbyus
  Is there an android tv image out there where I can install netflix? eclay 2 8,783 07-18-2017, 08:49 AM
Last Post: eclay
  Orange Screen All versions of Android TV XsoundXhoundX 17 33,589 05-19-2017, 01:27 AM
Last Post: Israeldelamo
  Screen wakeup Danja 17 33,510 12-22-2016, 05:30 AM
Last Post: Workaholic
  Xposed works! More or less. How To: Manually install Xposed Framework hyperlogos 6 23,618 10-21-2016, 08:11 AM
Last Post: webterminator77
  Touch not working with Android and touch screen erichardson30 5 14,553 09-13-2016, 11:12 AM
Last Post: MarkHaysHarris777
  Can I rotate Screen Android 5.1.1 for LCD (not rooted) steveslim 4 11,440 09-04-2016, 09:35 PM
Last Post: steveslim
  What happened to the images for the7" touch screen? tanarri 1 5,643 08-29-2016, 11:37 AM
Last Post: Ghost
