Problem with updates: Repository 'Debian bookworm' changed its 'non-free component'
Hi guys,
I seem to have a problem with updating Mobian:
Whenever I try to update it, it says:
All packages are up to date.
N: Repository 'Debian bookworm' changed its 'non-free component' value from 'non-free' to 'non-free non-free-firmware'
N: More information about this can be found online in the Release notes at: https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split
Does anybody know what I have to do in order to change the repository settings (if that's the problem) so that I get updates again?
Best,
A
Change (or add) non-free-firmware to /etc/apt/sources.list (as described by the mentioned link).
Thank you!
But what exactly do I have to paste into /etc/apt/sources.list in order to get updates again?
Just replace 'non-free' with 'non-free-firmware'
Thank you!
I changed the entry from
deb https://deb.debian.org/debian bookworm main
to
deb https://deb.debian.org/debian bookworm main non-free non-free-firmware
This has changed things, but instead of getting the zillion packages (that ought to be expected after weeks without upgrades)  it looks like this:
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://repo.mobian.org bookworm InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anything I can do in order to get upgrades again?
(08-31-2023, 08:16 AM)Anna Wrote: I changed the entry from
to
It seems everything is actually working as expected.
Debian Bookworm = Debian Stable (currently), which means updates aren't as often as f.e. Stable does not get new upstream versions, only fixes to (serious) bugs applied to the version in Stable.
AFAICT the 12.1 point release was on 22nd July and the 12.2 point release is scheduled for 7th October at which point you should get a bunch of updated packages.
This is a feature, not a bug ;-)
But you should add the following line to get security updates:
deb http://security.debian.org/debian-security bookworm-security main non-free non-free-firmware
Those updates could come in at any time when a security issue is found (and fixed).
(08-31-2023, 08:42 AM)diederik Wrote: But you should add the following line to get security updates:
Done, thank you!
https://blog.mobian.org/posts/2023/03/11...-firmware/
  Mobian MMS/SMS text problem bcnaz 16 38,627 06-23-2026, 06:53 AM
Last Post: mehdy
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 67,032 12-24-2025, 12:11 AM
  atinout binaries for mobian/debian? NeutralGrey 4 5,545 10-31-2024, 04:16 AM
Last Post: astylethargic
  Mobian repository status henrythemouse 16 23,796 04-10-2024, 10:02 AM
Last Post: diederik
  No volume control after latest updates Zebulon Walton 19 21,263 09-08-2023, 08:28 AM
Last Post: jessencan
  Haven't seen updates in a while Zebulon Walton 3 5,158 06-24-2023, 04:29 PM
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 10,734 06-06-2023, 06:36 AM
Last Post: freelectro
  Debian bookworm security repo user641 2 5,046 02-17-2023, 01:12 AM
Last Post: user641
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,600 12-22-2022, 07:10 PM
Last Post: acid andy
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 25,432 10-14-2022, 05:38 PM
Last Post: Krafter
