Cannot Boot Star64
Greetings! I'm looking for a bit of advice.
After numerous attempts, I am unable to get my Star64 board to boot.  I'm attempting to run Armbian, including the build by balbes150 (https://forum.pine64.org/showthread.php?tid=18344) and the build on the Armbian website.
I've read about setting the Component S1804 switches to boot from SD card, which I've tried. I also wrote an image to an eMMC module and tried booting from that (changing the S1804 switches accordingly).
I have a 3amp power supply purchased from Pine.
I'm using the serial console on pins 6, 8 and 10.  The only message I ever see is this:
BOOT fail,Error is 0xffffffff
return the switch to the factory state (flash 0,0) and show the log of the entire UART log from the power-on moment when starting any image from the specified theme (download, unpack and burn to the SD card, do not change anything after recording, connect to Star64 and turn on the power).
Please note, there is no bootloader (u-boot) in my images and they work exclusively in startup mode with built-in u-boot (factory state of the device). If you want to test the launch from an SD card, use Fishwaldo images, they have a built-in u-boot and they can work in both switch position options (SD and flashe).
(08-18-2023, 08:24 AM)balbes150 Wrote: return the switch to the factory state (flash 0,0) and show the log of the entire UART log from the power-on moment when starting any image from the specified theme (download, unpack and burn to the SD card, do not change anything after recording, connect to Star64 and turn on the power).
Thanks for the assistance!  Returning the switch to factory state got some much more interesting results, however it is still not booting successfully.  It occurs to me that this may be because I likely did not successfully update the bootloader according to your post on the Armbian boards. But before I attempt that again, I'll post the UART log:
U-Boot SPL 2021.10 (Jan 19 2023 - 04:09:41 +0800) DDR version: dc2e84f0. Trying to boot from SPI OpenSBI v1.2   ____                    _____ ____ _____   / __ \                  / ____|  _ \_  _| | |  | |_ __  ___ _ __ | (___ | |_) || | | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | | | |__| | |_) |  __/ | | |____) | |_) || |_   \____/| .__/ \___|_| |_|_____/|____/_____|         | |         |_| Platform Name            : StarFive VisionFive V2 Platform Features        : medeleg Platform HART Count      : 5 Platform IPI Device      : aclint-mswi Platform Timer Device    : aclint-mtimer @ 4000000Hz Platform Console Device  : uart8250 Platform HSM Device      : jh7110-hsm Platform PMU Device      : --- Platform Reboot Device    : pm-reset Platform Shutdown Device  : pm-reset Firmware Base            : 0x40000000 Firmware Size            : 288 KB Runtime SBI Version      : 1.0 Domain0 Name              : root Domain0 Boot HART        : 1 Domain0 HARTs            : 0*,1*,2*,3*,4* Domain0 Region00          : 0x0000000002000000-0x000000000200ffff (I) Domain0 Region01          : 0x0000000040000000-0x000000004007ffff () Domain0 Region02          : 0x0000000000000000-0xffffffffffffffff (R,W,X) Domain0 Next Address      : 0x0000000040200000 Domain0 Next Arg1        : 0x0000000042200000 Domain0 Next Mode        : S-mode Domain0 SysReset          : yes Boot HART ID              : 1 Boot HART Domain          : root Boot HART Priv Version    : v1.11 Boot HART Base ISA        : rv64imafdcbx Boot HART ISA Extensions  : none Boot HART PMP Count      : 8 Boot HART PMP Granularity : 4096 Boot HART PMP Address Bits: 34 Boot HART MHPM Count      : 2 Boot HART MIDELEG        : 0x0000000000000222 Boot HART MEDELEG        : 0x000000000000b109 U-Boot 2021.10 (Jan 19 2023 - 04:09:41 +0800), Build: jenkins-github_visionfive2-6 CPU:  rv64imacu Model: StarFive VisionFive V2 DRAM:  8 GiB MMC:  sdio0@16010000: 0, sdio1@16020000: 1 Loading Environment from SPIFlash... SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment StarFive EEPROM format v2 --------EEPROM INFO-------- Vendor : PINE64 Product full SN: STAR64V1-2310-D008E000-00000021 data version: 0x2 PCB revision: 0xc1 BOM revision: A Ethernet MAC0 address: 6c:cf:39:00:75:99 Ethernet MAC1 address: 6c:cf:39:00:75:9a --------EEPROM INFO-------- In:    serial@10000000 Out:  serial@10000000 Err:  serial@10000000 Model: StarFive VisionFive V2 Net:  eth0: ethernet@16030000, eth1: ethernet@16040000 switch to partitions #0, OK mmc1 is current device found device 1 bootmode flash device 1 ** Invalid partition 3 ** Couldn't find partition mmc 1:3 Can't set block device ** Invalid partition 3 ** Couldn't find partition mmc 1:3 Can't set block device Hit any key to stop autoboot:  0 ** Invalid partition 3 ** Couldn't find partition mmc 1:3 Can't set block device Importing environment from mmc1 ... ## Warning: Input data exceeds 1048576 bytes - truncated ## Info: input data size = 1048578 = 0x100002 ** Invalid partition 2 ** Couldn't find partition mmc 1:2 Can't set block device ## Warning: defaulting to text format ## Error: "boot2" not defined switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 332 bytes read in 6 ms (53.7 KiB/s) 1: Armbian Retrieving file: /boot/uInitrd 24114630 bytes read in 1012 ms (22.7 MiB/s) Retrieving file: /boot/Image 8085097 bytes read in 342 ms (22.5 MiB/s) append: root=UUID=309ddfae-1d04-4ad9-83ea-12a45bfa3520 console=ttyS0,115200n8 console=tty0 earlycon=sbi rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles Retrieving file: /boot/dtb/starfive/jh7110-pine64-star64.dtb 48314 bytes read in 13 ms (3.5 MiB/s) kernel_comp_addr_r or kernel_comp_size is not provided! SCRIPT FAILED: continuing... Card did not respond to voltage select! : -110 No EFI system partition ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110FAILED:
Yes, you haven't updated the loader. Now you have the correct state of the switch to start the update. Download the update file, write it to the SD card, insert it into Star64 and turn on the power. Wait for the update to finish (about 1-2 minutes) and turn off Star64. You can burn the ArmbianTV image to the same SD card and now it will work. I recommend using the LEGACY version, all the hardware works in it. The CURRENT and EDGE versions are test versions with a new kernel, some of the hardware is not working in them yet. If you need a working browser, I recommend using Alt Linux images, they have a full-fledged browser.
(08-19-2023, 12:33 AM)balbes150 Wrote: Yes, you haven't updated the loader. Now you have the correct state of the switch to start the update. Download the update file, write it to the SD card, insert it into Star64 and turn on the power. Wait for the update to finish (about 1-2 minutes) and turn off Star64. You can burn the ArmbianTV image to the same SD card and now it will work. I recommend using the LEGACY version, all the hardware works in it. The CURRENT and EDGE versions are test versions with a new kernel, some of the hardware is not working in them yet. If you need a working browser, I recommend using Alt Linux images, they have a full-fledged browser.
Thank you once again. I just got Sid Legacy - XFCE booted (though I'm still only using the serial console for now).  WiFi is working and all is well thus far.
I've seen a few other places mention that doing an apt update is not advisable. Is that the case for your current build?
My final question would be, is there anything I can do to help test?
(08-19-2023, 09:50 AM)jdoolin Wrote: I've seen a few other places mention that doing an apt update is not advisable. Is that the case for your current build?
you can safely update the system, a different principle of using packages (deb) is used here, this is a standard system from network repositories and it can be updated, install any packages from network repositories without restrictions.
  Star64/Starpro64 kernel building global 1 3,307 06-30-2026, 12:17 PM
Last Post: tgbgreen
  Totally disabling auto-boot when charger is plugged in? A Mnesia 1 1,513 06-03-2026, 12:22 PM
  Star64 distro overview October 2023 tantamount 7 9,846 01-11-2025, 09:12 AM
Last Post: gounthar
  star64 bootable images, u-boot, sbi, forum? hexdump 5 8,220 11-27-2024, 11:13 AM
  Need help in understanding Yocto and U-boot build process for Star64 InterestedinFOSS 2 4,302 06-05-2024, 04:29 PM
Last Post: yogo1212
  [Star64] UART activity stopped yogo1212 0 2,337 02-11-2024, 04:34 PM
Last Post: yogo1212
  Star64 Mechanicals nbxmike 4 7,103 01-16-2024, 04:35 AM
Last Post: oilumiun12
  Armbian and AltLinux for Star64 (RISC-V) balbes150 28 31,877 11-24-2023, 06:26 AM
Last Post: balbes150
  [Article] Star64 JH7110: Experiments with OpenSBI (Supervisor Binary Interface) lupyuen 0 2,713 10-28-2023, 06:55 PM
Last Post: lupyuen
  [Article] Star64: Strange Workaround for TFTP Timeout in U-Boot Bootloader lupyuen 0 3,040 10-05-2023, 07:22 PM
Last Post: lupyuen
