Using optical drives with Pinephone
Hello all, I'm curious as to whether anyone has been able to use an optical drive such as a USB DVD drive with a Pinephone or Pinephone Pro?
My use case is - my preferred way to acquire music is to buy a CD. I would like to set up a Pinephone as a one-stop shop for listening and ripping CDs. I have been able to do this before with a Samsung Galaxy S20 5G under Android.
My Pinephone running Postmarket OS recognizes USBdevices and can also run with a Nexdock. It can read flash drives too. If I use an optical drive, including powered variants, it shows under lsusb but not fdisk -l.
Before I go down a complete rabbit hole trying to get this to work, I wanted to ask if anyone had used this setup with any success? Or if it works on a Pinephone Pro I can upgrade. I'm wondering if the hardware supports it but there's something missing at the Linux kernel level, or need certain drivers.
Happy to post logs etc. but mainly wondering if anyone else has made this setup work previously?
i haven't tested usb based optical drive on pinephone regular or pro. i have a desktop and laptop. however i recently used optical drive to read some disks into hard drive for storage.
i don't know does arm based pp need drivers for usb optical drive. maybe i test, but not quickly. physical power is an issue though.
optical medias will not be shown in fdisk or lsblk, they work little differently.
my guess is, this is a bad idea. i would use x86-64 computer for this.
you may want to check following programs though. these are text based programs.
cdparanoia
crdskin
wodim
following is what i think of optical medias:
https://barrelmem.s3.eu-north-1.amazonaw...201632.jpg
Your image made me laugh. I often feel similar about optical media...
Okay so - it turns out that reading optical drives requires the kernel module sr_mod. This is not included by default in Postmarket OS or Manjaro for Pinephone. I tried installing Mobian instead - it doesn't seem to be activated my default but you can use:
sudo modprobe sr_mod
And it activates. It will then read the optical drive!
Interesting learnings...
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,178 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,068 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,622 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,694 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,177 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,767 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,762 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,353 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,467 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,004 03-25-2025, 08:51 PM
