Broke pinebook GUI, what to do, fix or install new?
So a while back I managed to break the stock Neon OS when trying to switch from Plasma to something else. There was some change I did to systemctl and it broke it. It will boot to a command prompt. I set it aside and ignored it for a while.
I know Neon has been out of style for a while so I don't know how much effort I should put into fixing it, or should I just put something else on it?
I'm noticing that there isn't a nice list of "mainstream" Linux operating systems for it like there is for the Pinebook Pro, which sucks.
Is there an OS I can install onto it without it being to hacky to get it working? I just want something I can use instead of having to tinker with all the time.
At the moment I'm using NetBSD from a SD card but I have to use a different WiFi adapter.
Thanks!
They are community builds, not official, but Armbian will likely be a solid bet for getting an OS you don't have to tinker with, getting up and going quickly.
https://www.armbian.com/pinebook-a64/
(07-10-2023, 07:39 AM)tophneal Wrote: They are community builds, not official, but Armbian will likely be a solid bet for getting an OS you don't have to tinker with, getting up and going quickly.
I installed Armbian with XFCE onto an SD card and it's not perfect but it works. Pretty neat. I'm typing this on it right now. Thanks.
  DietPi OS for Pinebook MichaIng 5 17,134 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,592 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 104,314 09-26-2023, 03:18 PM
  Orignal PineBook jwp1000 1 4,471 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,731 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,422 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,737 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,441 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,515 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 6,188 12-25-2020, 04:40 PM
Last Post: ford442
