Pinephone pro packet injection for internal wifi chipset
Hello. Does anyone knows how to enable packet injection or monitor mode for internal wifi chipset of pinephone pro? OS is kali linux with Phosh.
Sent from my SM-A127F using Tapatalk
(06-29-2023, 09:34 AM)covar Wrote: Hello. Does anyone knows how to enable packet injection or monitor mode for internal wifi chipset of pinephone pro? OS is kali linux with Phosh.
To my knowledge, this is not possible on the PinePhone Pro. It would require the firmware to support the two modes, which it doesn't and no released firmware does.
So do you know how to solve that problem?
writing a new open source driver requires having a complete datasheet including the monitor mode instructions, you would need to get the info used to build the current driver and compare it with the documents released by the manufacturer.  Sometimes this requires decapping the IC and connecting logic probes and figuring out how the the chip works, this is how some FOSS drivers are made for popular hardware with weak documentation.  Is modern 802.11 hardware still vulnerable to deauth and packet injection attacks?  Monitor mode is always useful though.
What Kali Linux recommends you to do is to attach a supported (check the list first before you buy!) USB C WiFi dongle and to use that one. (And by "supported", I mean that it needs to supports monitor mode under GNU/Linux. Not every WiFi chipset that works in principle also works for monitor mode!)
I do not think there is any other solution. The kernel driver for the internal WiFi is Free Software, but the firmware that runs on the WiFi chip is not, and it does not support monitor mode, so the driver cannot support it.
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,404 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 835 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,667 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 4,226 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,849 08-18-2025, 04:12 AM
  RTKLIB PinePhone Pro GPS jlaba 1 2,877 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 15,199 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,892 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,555 09-06-2024, 02:39 AM
Last Post: zvavybir
  Pinephone pro shuts down immediately after login covar 4 6,846 07-03-2024, 10:59 AM
Last Post: covar
