Battery drain when off
I bought a Pinebook Pro recently, and I've been using it with Tow-Boot installed and dual-booting Ubuntu and Manjaro. I've been having problems with excessive battery drain, even when powered off. I just did a test, and in six hours, the battery dropped from 99% to 59% after shutting down Ubuntu 22.10.
Is this a known problem? Is there a workaround or fix? I'm quite able to compile a custom kernel, if that's what it takes, although a pointer to a suitable config file would be helpful.
Thanks!
It sounds like Ubuntu is not actually turning it off. My latest one will probably use that much battery during 6 hours of active use, and the battery does not drain noticeably in weeks of power-off state. But I use neither Ubuntu nor Manjaru.
:wq
  Replacement battery for PineBook Pro DrYak 5 9,365 02-28-2026, 09:17 PM
  Bad replacement battery? chris88233 4 7,125 11-14-2024, 06:05 PM
Last Post: reukiodo
  Lithium Battery Connector Franestra 0 3,281 04-02-2024, 01:52 AM
Last Post: Franestra
  Bypassing the Battery gilwood 0 2,845 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 4,870 12-26-2023, 04:28 PM
Last Post: DrYak
  Battery replacement mjc 2 6,669 09-26-2023, 01:08 AM
Last Post: david-lechner
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,563 07-09-2021, 08:45 PM
Last Post: moonwalkers
  Battery doesn't charge mspohr 5 10,428 06-11-2021, 08:42 AM
Last Post: mspohr
Question Powering off & won't power back on w/o battery disconnect jimsurvak 5 10,369 11-10-2020, 08:42 PM
  Horrible screen flicker/strobe on battery power mattjb 19 40,588 09-14-2020, 03:19 AM
Last Post: m.bakhterev
