Unsuspend → Black screen
Sometimes, when pressing the power button to un suspend the phone, the screen stays black.
I noticed two different cases:
- Swiping from the top of the screen sometimes "wakes it up" (try it if it happens to you, can save you a reboot).
- Nothing can get the screen to display something, I have to hard-reboot (not just boot, I have to stop it first by an ~8s press, then to boot it with a ~4s press).
So yes, Mobian is still running when it happen, I "tested" it only once as I was listening music, the screen was staying black while the musing was playing. I had to hard reboot this time.
Does it happen to you too?
This only happens to me when I set the brightness level on the lowest possible setting.
(03-10-2023, 11:59 AM)mdk Wrote: Does it happen to you too?
Yes, since the beginning of the year, a few times a week at lest.  Sad
I guess it hast to do with the "flipping frames bug".
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
I think what you are seeing is actually another symptom of the mesa bug discussed, e.g., here: https://forum.pine64.org/showthread.php?...#pid116068
The good news is that this is already fixed in upstream mesa and in faster-moving distributions (e.g., Manjaro). The bad news is that Mobian has not picked up the fix yet.
It doesn't happen to me but I very rarely lower the brightness.
(03-13-2023, 08:09 PM)Kevin Kofler Wrote: I think what you are seeing is actually another symptom of the mesa bug discussed, e.g., here: https://forum.pine64.org/showthread.php?...#pid116068
Just upgraded mesa (yes it landed!).
Never lowered the brightness less than 25% just in case.
And the bug still occur to me, it just occurred right now, had to hard reboot (phone was not replying to pings / can't ssh).
Reading the journal, I don't see any activity (before the reboot) during the time I tried to wake it up, it looks like:
    Mar 24 17:06:51 mobian kernel: Disabling non-boot CPUs ...
    -- Boot b7621df8a04a41b58c2b0b31bdf413c2 --
    Mar 24 17:28:52 mobian kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
so clearly no activity here around 17:25 when I tried multiple time to press the power button before hard-rebooting it. I don't know what happen, any idea on how I could diagnose this? I bet serial over jack won't be of any help neither here...?
OK it clearly changed since the mesa bug. One of the two cases dissapeared: the one that was resolved by swiping the screen.
Now it happen always with the same symptoms:
- Always after a long time on charge, as if hitting 100% charge has something to do with it.
- When hitting the power button the blue led blinks like if I had a notification.
- Can't ping nor SSH
- Have to hard reboot (8s to power down + 4s to power up).
Noticed something else!
When the screen stays black the phone is hot.
It often happen while charging, maybe after hitting 100%.
When it happen, if I unplug it, it changes nothing: the phone stays hot, the screen stays black when pressing the power button, can't ping nor ssh.
Have to hard reboot.
(05-09-2023, 07:50 AM)mdk Wrote: Noticed something else!
I'm still having this issue, which is unfortunate, because I'd be totally fine with say, Manjaro, if only it had Nheko, and the camera app that Mobian uses, as well as the keyboard case being BARELY functional. Anything new on this issue?
Same here! Often in the morning (plugged in over night), it's dead...
  How to add an homemade app to the main screen? JChdeL 2 106 Yesterday, 09:41 PM
  New Install, apps start but don't show up on screen?! RT3 2 1,729 07-18-2025, 07:56 PM
  On-Screen Keyboard Arrow Keys biketool 10 5,128 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,906 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,358 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 1,737 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 1,790 06-24-2023, 01:55 PM
Last Post: freelectro
  Lock screen question: always squeekboard tuxcall 1 2,598 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 2,012 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 3,288 08-08-2022, 09:38 AM
Last Post: andrew907
