Boot log analyses -> GPU no regulator (mali) found
Hi all,
I'm analyzing boot log from journalctl.
I have found regulator error. Is it possible to fix it ?
lima 1c40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: gp - mali400 version major 1 minor 1 mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: bus rate = 200000000 mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: mod rate = 297000000 mars 06 14:51:17 mobian kernel: lima 1c40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found mars 06 14:51:17 mobian kernel: fbcon: Taking over console mars 06 14:51:17 mobian kernel: [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
Thanks a lot for your advice.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,540 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  boot gets stuck shortly after disk decryption vortex 9 12,515 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 11,088 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 5,337 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,498 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 3,180 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 5,060 03-17-2023, 07:26 AM
  [solved] Black screen at boot time mdk 0 2,795 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,597 01-04-2023, 06:46 PM
Last Post: 3x5co
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 7,150 12-31-2022, 10:56 AM
Last Post: DrPlamsa
