Metis package can't update
I have pinebook with Manjaro OS. I have metis version 5.1.0.p10-2 and notification for available update to 5.1.0.p11-1. But when I try to update it I have result below:
reparing...
Synchronizing package databases...
Cloning metis build files...
Generating metis information...
Checking metis dependencies...
Resolving dependencies...
Checking inter-conflicts...
Download of inetutils (2.3-1) started
Download of inetutils (2.3-1) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing inetutils (2.3-1)...
Running post-transaction hooks...
Reloading system manager configuration...
Arming ConditionNeedsUpdate...
Updating the info directory file...
Building metis...
==> ERROR: metis is not available for the 'aarch64' architecture.
What's a problem, how to fix it?
The metis package is coming from the AUR https://aur.archlinux.org/packages/metis
AUR packages use a file called a PKGBUILD which has instructions to build the package. In this case, the metis PKGBUILD has the line
arch=(x86_64)
meaning it only supports the x86_64 architecture.
If you want to build it you can try from the command line
sudo pamac build metis
Then when prompted press 'e' to edit the package build. You can edit the line above to
arch=(any)
then see how you go. You might need to make further changes to get the build to succeed on arm64.
Personally I would try to configure my update utility not to automatically upgrade from the AUR.
If you want to update just the pacman packages you can run
sudo pacman -Syu
  Locked out after update Shylocked 5 3,860 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 9,330 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 3,280 09-16-2023, 09:41 AM
Last Post: jd50i
  invalid or corrupted package (PGP signature) Mangustis 0 2,559 02-21-2023, 04:50 PM
Last Post: Mangustis
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 8,042 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 4,205 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 4,571 05-10-2022, 01:52 AM
Last Post: diyagabriel
Big Grin Selling Pinbook Pro AND pinephone convergence package poltergiest 2 4,627 03-08-2022, 10:12 AM
Last Post: poltergiest
  Wont charge when powered off, and update question pineymousepad 7 11,735 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 2,924 11-18-2021, 06:37 PM
Last Post: reundo
