Is Quartz64 compatible with official 7'' Raspberry Pi display?
Hello everyone,
I'm wondering what the title says; I've noticed the Quartz64 Model B has a visually identical DSI connector to the Raspberry Pi. I have a few extra 7'' official RPi touch displays: can I expect them to work?
it is (sort of) compatible; the pinout of the DSI connector is the same as the RPi, but software won't be a plug-and-play affair.
You will need knowledge of device trees to make the kernel try to use the panel, the kernel needs to be built with CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN (yours likely is), and you need to use the device tree compatible raspberrypi,7inch-touchscreen-panel.
Unfortunately for u-boot bug reasons most (if not all?) images for the Model B don't have device tree overlays enabled as of the time of writing, so you'd need to grab a copy of the kernel source, do "make dtbs", copy the dtb from arch/arm64/boot/dts/rockchip/ into your device tree folder in /boot and then point your extlinux.conf at it. I'll look into fixing the fdt overlay thing when I'm back from FOSDEM I guess.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  Hardware Feature Suggestion for Quartz64: SPI Flash Hardware Write-Protect Independent Researcher 0 836 08-30-2026, 07:19 PM
Last Post: Independent Researcher
  Quartz64 Zero HDMI grobbs 2 2,953 05-03-2025, 11:04 AM
  Quartz64 Model A fan TeutonicTovarish 2 4,972 07-08-2024, 07:19 AM
Last Post: p1x3l3d
  gpio on Quartz64-a jyoung 3 5,321 05-24-2024, 06:41 AM
Last Post: Randomuser
  SD card slot in Quartz64 model B psic4t 1 4,061 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 3,737 10-13-2022, 07:43 PM
Last Post: dml-pc
  Case for the Quartz64 Model B? kuleszdl 1 5,559 06-05-2022, 02:43 PM
Last Post: CounterPillow
  SPDIF TOSLink Adapter Hat for Quartz64 CounterPillow 2 7,407 10-09-2021, 08:46 AM
Last Post: Bullet64
  Display options KJ6OHG 2 8,155 07-10-2021, 07:33 PM
Last Post: zer0sig
