Crash with Wifi/BT module attached
Yea, sorry I couldn't help CHeitkamp Sad
Will let you know as soon as tllim gets back to me.
(06-06-2016, 04:47 AM)Luke Wrote: Yea, sorry I couldn't help CHeitkamp Sad
Based on Luke description, we need to send a replacement module to you. Please PM me with your name, address, and phone number, I will handle the replacement. I will honor all finding from IRC chat support "Luke" so that backer no need to repeat the process again.
(06-06-2016, 02:25 AM)pfeerick Wrote: If you think the APX803 is getting hotter than say around 40*C at start up, or the power consumption of the pine64 is significantly more than 300-350ma whilst starting up, then I think there is something major wrong with the wifi board.
The board draws ~850mA with the wifi board connected.
(06-06-2016, 08:41 AM)tllim Wrote: Based on Luke description, we need to send a replacement module to you. Please PM me with your name, address, and phone number, I will handle the replacement. I will honor all finding from IRC chat support "Luke" so that backer no need to repeat the process again.
Thank you, I will send you an PM later.
Glad we got you sorted CHeitkamp - and thanks for helping out others in need in the chat +1
WTF? It sounds like Luke and tllim are fixing you up, but my 2cents worth is that the wifi module is faulty... I didn't get anywhere near that power consumption even with the brief stress test maxing the CPU out!!! Hope to hear good news that you have more luck with a replacement!
Well I'm having these crashes too.
I bought TWO Pine64 2GB models and two wifi/bt adapters.
On ubuntu xenial, they both go in endless reboot cycles.
On Android, one went in an endless reboot cycle and one powered up, but when I tried to turn on wifi or bluetooth nothing happened, and it went back off.
I'm using an official Raspberry Pi 3 adapter that provides 2.5A, so that should be enough, no?
Not good ....
  [split] Better WiFi/BT module? moriel5 3 10,149 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,476 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 41,667 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,042 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,364 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,271 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,444 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 5,993 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,102 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 9,832 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
