Warning, 5.5mm barrel-style power cables
I let someone look at my pinecil, they grabbed a standard 5.5mm 12v barrel-style power cable for the bench power supply assuming the pinecil used that standard and did the old push&twist to force it in.
After a few seconds of effort my associate had a stupid look on their face holding the connector cable but the center pin from the pinecil was jammed tight into the barrel connector.
Fortunately I was able to re-insert the pin and solder the broken power line back together, though certainly not as strong against a similar attack it works again over USB C (obviously) and the repaired barrel power port too so all is good.
(02-26-2021, 02:26 AM)biketool Wrote: I let someone look at my pinecil, they grabbed a standard 5.5mm 12v barrel-style power cable for the bench power supply assuming the pinecil used that standard and did the old push&twist to force it in.
Pinecil DC Jack is 5525 type which means 5.5OD 2.5mm ID, don't force jam the 5521 plug. The 2.5mm ID stick is too large for 2.1mm ID hole.
Read the Pinecil label, clearly stated 5525 type
That person breaks stuff, but IMHO worth posting the warning not as a complaint but as 5521 is common and plenty of stuff breakers out there will not read or understand the label.
Original planning is using 5521 socket instead of 5525. However, there is no 5521 type for such type of socket :-(
https://www.chipdip.ru/product/dc-005
This one?
This one?
This appears to be a 5521(5.5mm outside diameter X 2.1mm inside diameter) which is the wrong size though very common for 12v power.
There is a Warning in the Pinecil Wiki page also about DC Barrel and to use the Correct size 5.5mm, 2.5mm or DC5525.
https://wiki.pine64.org/wiki/Pinecil
  pinecil v2 dosent negotiate power moses 0 460 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,969 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 967 03-02-2026, 09:56 AM
Last Post: FZB
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,961 05-15-2025, 10:41 AM
Last Post: dreieck
Question Pinecil v2 power cycles at higher voltages? clemon79 3 6,818 08-10-2024, 05:47 AM
Last Post: RevAngel
  Connecting a power supply to the Pinecil jon_bondy 1 3,637 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 13,700 02-29-2024, 07:33 PM
Last Post: Okedokey
  Asus laptop power supply can also power Pinecil biketool 9 18,745 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  PD-EPR support and power rating over USB Joey_bikefast 1 3,946 11-05-2022, 01:32 PM
Last Post: River
  Warning: Don't try T12 tips csiwek 4 12,641 11-05-2022, 01:19 PM
Last Post: River
