Latest update
(11-01-2022, 09:10 AM)Eugo Wrote: It's gotten worse - it won't ring when suspended - the caller can't get me, call isn't registered, doesn't ring, no trace anywhere except on caller's phone.
As much as I hate to mess directly with the modem(s) - haven't had to do that since 1992 or so - it seems I finally should do that. Is there any short list of where and how to adjust settings, something like mmcli 101?
This link is most likely everything you need Smile
https://github.com/the-modem-distro/pinephone_modem_sdk
If you want to research more then see here:
https://wiki.pine64.org/images/1/1b/Quec...l_V2.0.pdf
https://wiki.pine64.org/wiki/PinePhone#AT_commands
Thanks, guys. This will take me several days, and I have a feeling it won't be boring Smile.
In the end, I may even achieve to have a, well, normal phone.
The firmware upgrade won't, I'm getting a
QUECTEL Mobile Broadband Module is not currently updatable: The modem-power kernel driver cannot be used
The status I got is
[manjaro@manjaro-arm ~]$ sudo fwupdmgr get-devices
pine64 Pine64 PinePhone (1.2)
└─QUECTEL Mobile Broadband Module:
      Device ID:          976c4a39e87f61e6940ea6a8d39c583cfa99615f
      Summary:            Quectel EG25-G modem
      Current version:    EG25GGBR07A08M2G_01.002.01.002
      Vendor:            Qualcomm (USB:0x2C7C)
      Problems:          • Device requires AC power to be connected
      GUIDs:              db379a33-254f-5140-b37e-d36ae7e5c039
                          d18f31f1-a3fa-55a2-b4ed-decfbc1e004d ← USB\VID_2C7C&PID_0125&REV_0318&NAME_EG25GGB
                          1a2996cb-f86e-5583-a464-e1b96e1c6ae9 ← USB\VID_2C7C&PID_0125&REV_0318
                          587bf468-6859-5522-93a7-6cce552a0aa3 ← USB\VID_2C7C&PID_0125
                          22ae45db-f68e-5c55-9c02-4557dca238ec ← USB\VID_2C7C
      Device Flags:      • System requires external power source
                         • Updatable
(11-02-2022, 08:41 AM)Eugo Wrote: The firmware upgrade won't, I'm getting a
I have flashed new firmware to modem like 300 times and every time I have used Biktorgjs flashall script.
Please find instructions here (I think it is fairly easy)
https://github.com/the-modem-distro/pine.../tag/0.7.0
Or should I just boot into PmOS and do it there?
(11-02-2022, 10:04 AM)Eugo Wrote: Or should I just boot into PmOS and do it there?
I have done it maybe 250 with PostmarketOS Big Grin.
So that should work - atleast with that Biktorgjs script.
But it should work with Manjaro, Arch and Mobian also.
The status I got is
                         • Updatable
It says directly in the output what to do:
If you connect AC (a power cable) it should work fine. Alternatively the flashall script will work too but fwupd is also very easy to use.
I did connect the power cable after that, but it still gives me this. It's charged 100%, so I know the power is on, and when I disconnect the cable and reconnect it, it plays the two ticks sound as always. and the get-devices command still reports this.
After a reboot, a slight change:
      Update Error:       The modem-power kernel driver cannot be used
                          • Supported on remote server
                          • Updatable
                          • Device supports switching to a different branch of firmware
Tried to switch again, just in case the above message is wrong, but I still get „QUECTEL Mobile Broadband Module is not currently updatable: The modem-power kernel driver cannot be used“.
                          • Updatable
That error is a bit unexpected. You might want to join the bridged community channel for some further input: https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms
Believe it or not, this turned out to be a case of programmer's alzheimer. It was the /usr/lib/udev/rules.d/90-modem-eg25.rules
which I edited as described at couple of places, with
ON ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/control}="on"
...except that I completely forgot that I did that on Mobian, not Manjaro Phosh. Now that I repeated it, it seems to work. Did only one quick test, though, and it passed. Will test some more, when I recharge it, and then, hopefully, mark this as solved.
  Using too much juice since last update Eugo 20 20,118 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 12,634 02-13-2024, 01:19 AM
  Firefox issue with latest update Barugon 6 7,760 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 51,740 07-28-2022, 12:40 PM
Last Post: johaennessen
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 6,542 06-17-2022, 07:48 AM
Last Post: hollerpots
  How to disable automatic update checks bdicewk 4 6,309 06-12-2022, 08:10 AM
Last Post: bdicewk
  Locked out after update bnbcwllc 2 4,162 06-08-2022, 04:46 AM
Last Post: bnbcwllc
  Keyboard case stopped working on pacman update rotwang 5 7,426 05-07-2022, 09:17 PM
Last Post: rotwang
  Pinephone stuck on 'something went wrong' after update gofishus 1 3,713 03-06-2022, 05:48 PM
Last Post: fxc
  Lockup during update, force shut down and try again? tgz 5 10,119 12-22-2021, 03:11 PM
Last Post: tk1107
