quartz64 model b 2x20 max power
what is the maximum power available on the 3.3v and 5.0v rails assuming only ethernet is attached to the quartz64 model b?
Check the schematic for details.
The 3.3V pins on the GPIO header are fed by VCC3V3_SYS, which is powered from CH2 on the RK809 chip, which is capable of 2.5A of output current. I'd say 2A is a reasonable upper limit to assume for any real world design here.
The 5V seems to go through an SGM40655 over-voltage protection IC, which has a max rated output current of 4.5A. Everything else is derived from this, so I think I'd once again say <1 to 2A is probably a good limit, depending on how much you draw from the 3.3V.
(For situations where anything is plugged into USB, the power available on the 5V rail is obviously going to be impacted.)
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 5 23,887 05-05-2026, 07:57 AM
Last Post: kapqa
  How to reengage PCIe when reapplying power? rotdrop 1 2,381 10-10-2024, 06:49 AM
Last Post: rotdrop
  No boot...power light shows green 98cwitr 2 6,347 01-19-2024, 07:31 PM
Last Post: Darin755
  Quartz64 seeming died Darin755 0 2,369 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 5,284 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 4,209 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 4,506 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 20,474 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 24,757 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 22,427 01-23-2023, 03:31 AM
Last Post: balbes150
