Tow-Boot issue
I was recently trying to install Mobian (installer doesn't work) and postmarketOS (pmbootstrap fails). Since I couldn't get them to work, I decided to go back to Manjaro but, unfortunately, Tow-Boot refused to boot into USB mass storage mode. It would just buzz four times, buzz another ten times and then power off. It turns out that Tow-Boot requires a bootable OS in eMMC in order to boot into USB mass storage mode even though Tow-Boot is installed in SPI. I ultimately had to install an OS onto a SD card, boot from that and install to eMMC from there in order to get everything working again.
Just posting this here in case anyone else runs into this issue.
Same Problem here and your posting saved my day !!!
Many, many thanks and best regards,
Andrew
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,758 08-18-2025, 06:15 PM
  No rk2aw boot menu jebez 7 5,548 07-09-2025, 07:12 AM
Last Post: mikehenson
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 17,808 03-13-2025, 08:40 PM
Last Post: pcb
  PinePhone doesn't boot anymore lapin 3 4,001 09-13-2024, 10:09 AM
Last Post: lapin
  How to boot from SD card in PPP joespodie 2 5,096 08-02-2024, 02:49 PM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 4,753 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 7,894 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 9,447 11-20-2022, 05:58 AM
Last Post: wibble
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 5,788 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 13,438 06-20-2022, 11:16 AM
Last Post: elode
