Tow-boot on Pinephone beta edition
Did anyone managed to make tow-boot working on pinephone beta edition ?
I tried releases for pinephone and pinephone pro, flashing to SD card, but none of them was working. There is no reaction on pressing power button - not even blinking led light. I wanted to test Mobian, but there is no way without working tow-boot.
(09-04-2022, 02:39 AM)saddamus Wrote: Did anyone managed to make tow-boot working on pinephone beta edition ?
 what do you mean by "working" ?
 i have manjaro and tow-boot on the emmc that boots fine
 but i cant boot from sd with p-boot or with wiped u-boot
(i have a thread on this)
 ezik
Now I'm a bit lost.
I wanted to test Mobian, but for this the phone has to be flashed with tow-boot. I have downloaded the tow-boot image and flashed to SD card. Before the SD card was flashed with Jumpdrive.
So what I have finally done is flashed EMC with mobian and SD with tow-boot. After this operation, phone does not react on power button at all - not even blinking.  Not sure if this is right after your question, but i assume, there should be at least some reaction - even if system couldnt boot, there should be some sign of live from tow-boot residing on SD card - am I right ?
(09-04-2022, 12:44 PM)saddamus Wrote: Now I'm a bit lost.
 i think you can't install tow-boot to sd. the image is for flashing to emmc
 i don't know what happens if you flash mobian to sd (i'll try it)
 when you boot the tow-boot image it tells you to flash to emmc
 and maybe the mobian image is withuot boot loader because pinephone boots from sd first
 ezik
This is right, mobian doesnt have bootloader, but tow-boot does not boot the phone, regardless if its on SD or EMC. Volume up + power, volume down + power or power does not bring any reaction.
Is your device beta edition  with 3gb of ram ?
(09-06-2022, 02:54 AM)saddamus Wrote: This is right, mobian doesnt have bootloader, but tow-boot does not boot the phone, regardless if its on SD or EMC. Volume up + power, volume down + power or power does not bring any reaction.
 for me it doe's boot. now i have tow-boot and manjaro on the emmc and latest mobian on the sd
 untouched it boots to manjaro end with volume down it boots to mobian
 and it is beta edition (with 2gb)
 the light color and the vibration are as expected
 red - vibrate - yellow for emmc boot  and rered - vibrate - aqua for sd boot
 are you sure tow-boot is installed correctly on emmc ?
 i think you got all wrong
 tow-boot should be copyed to the emmc that may have any OS, and then insert sd with mobian
 ezik
https://tow-boot.org/devices/pine64-pinephoneA64.html
ezik
When I went to install tow-boot onto my Pinephone A64, I wasn't really paying attention to the file I downloaded. I just used xzcat and piped it to dd and wrote it to my SD card. And, it didn't work. After scratching my head a bit, I finally realized that the file you download contains 2 disk images and is not directly flashable.
When you download tow-boot from github: https://github.com/Tow-Boot/Tow-Boot/rel...005.tar.xz you have to extract it.
I used: unxz pine64-pinephoneA64-2021.10-005.tar.xz
Then  untar the tar file: tar -xf pine64-pinephoneA64-2021.10-005.tar
- There is probably a single command that will do this, but I was too lazy to look it up.
You'll end up with a folder with 2 .img files. dd or etcher... the mmcboot.installer.img image file to your SD card. Pop the SD card into your Pinephone and the tow-boot installer should boot and an install menu will appear on the phone screen.
Because the Pinephone A64 looks for the boot loader on the SD card then eMMC, it will boot off an SD card that has u-boot on it. If you don't want this you'll have to remove u-boot from the SD card. There are instructions on the wiki: https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
(09-06-2022, 10:10 AM)mark1250 Wrote: When I went to install tow-boot onto my Pinephone A64, I wasn't really paying attention to the file I downloaded. I just used xzcat and piped it to dd and wrote it to my SD card. And, it didn't work. After scratching my head a bit, I finally realized that the file you download contains 2 disk images and is not directly flashable.
 did those instractions work for you ?
 ezik
Haven't tried yet, but I will and gonna let you know. Thanx for clarification.
I flashed towboot .img to an SD card on my laptop. Inserted SD card and then started device. I selected the option to install towboot. Once completed I shut down device (power-off) and removed SD card. That was the end of any SD card in my Pinephone. I flash whatever I want now with my laptop and Balena Etcher and a usb cable.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,864 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,041 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,569 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,829 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,026 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,798 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,424 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,085 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,463 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,894 10-21-2025, 12:12 PM
Last Post: Richy_T
