Mobian on PPP
Where is the settings tool or how to install It? In the latest weekly omg that I installed on the SD, cannot see it
You will have to find an older img file to install.
Once an image with the Settings app is running, then the apt-get dist-upgrade command can not be used until further notice. We have to settle for apt-get upgrade until critical packages are no longer nominated for deletion with no replacement, and packages are no longer held back from upgrade.
Look for org.gnome.Settings.desktop in the /usr/share/applications directory.
Many thanks
  Experimental Mobian kernel patch for extended battery life teekay 15 13,015 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 16,255 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 2,442 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 6,596 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 1,553 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 3,953 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 1,641 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,075 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 1,595 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 1,706 10-14-2023, 11:57 AM
Last Post: mburns
