PP keyboard not working at all
Today my PP keyboard arrived, but doesn't work.
Since it's charging my PP, i suppose, the connection of the pins is fine.
Now I read in the instructions post, I need the KB151 driver. But before I reinstall the whole system, this results in the following questions:
1. How can I check, if this driver is present?
2. If it isn't, can I install it or do I have to reinstall the whole OS?
3. If I do have to reinstall the whole OS, how do I know if the kernel does include this driver (I read, that in stable, the driver is not present)?
Thanks for helping me
Try updating to the latest version of mobian. There were kernels without drivers for a while in May.
See https://forum.pine64.org/showthread.php?tid=16756
Although at the moment it is possible that a later update has affected charging and reporting of battery levels.
https://forum.pine64.org/showthread.php?...#pid111668
Thanks for your answer.
I am on the latest stable version. The other threads don't have a final solution as it seems.
In one thread is said, that it works now with the latest version, but with the latest version of what? That isn't mentioned (I asked there, too).
sudo modprobe kb151 tells me, that kb151 isn't there. The question remains: can I install that driver or must it be part of the kernel? Do I have to flash a version of the OS whose kernel contains it?
Thanks again
I don't know what I did, but it seems to work now. I didn't do anything special. But after another reboot it suddenly worked. Thanks. I'll mark this as solved.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,245 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,417 12-23-2025, 04:25 AM
  New camera app gnome-snapshot working on trixie? vusra 4 4,938 04-11-2025, 02:53 AM
Last Post: vusra
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,498 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 6,009 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 40,400 01-13-2025, 01:37 AM
  Calls 4G not working oliwierzgorniak 2 5,505 08-06-2024, 02:20 PM
Last Post: baptx
  Keyboard not popping up on QT apps 3x5co 1 3,386 02-08-2024, 11:45 PM
  Mobile internet via cellular network mostly not working Anna 18 26,850 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 7,835 01-17-2024, 05:53 PM
