Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro
(05-15-2022, 04:36 AM)fxc Wrote:
(03-26-2022, 07:29 PM)bcnaz Wrote: There should be some notices on this weakness  !
A Friend just wiped out her brand new Pro phone just by "using this Adapter" ..!
What is worse yet  ?
How about you cannot even buy a new Pro motherboad !
You MUST but Another Complete phone,  because you used an adapter that came with your phone....
I would suggest to open a ticket under support.pine64.org regarding a replacement. Attaching a picture of the defect to the ticket is advised.
For clarifications, there are big warnings on both, the wiki and the printed manuals (see https://wiki.pine64.org/wiki/PinePhone_P...time_setup and https://wiki.pine64.org/wiki/PinePhone#F...stallation). The mainboard is only currently not yet available in the store, I think the regular PinePhone's Braveheart Edition didn't have replacement parts and mainboards in the store back then either and I assume it makes sense for Pine not to produce a large amount of replacement mainboards if a new hardware revision is possible for the next batch. The mainboard itself will probably be however a large part of the overall phone price.
Well what I think is that the main board as a whole is never replaced. May be there is a part which is supposed to be replaced. And I hope it will be an easy task for pine to repair it.
What is worse yet  ?
For clarifications, there are big warnings on both, the wiki and the printed manuals (see https://wiki.pine64.org/wiki/PinePhone_Przameen and https://wiki.pine64.org/wiki/PinePhone#F...stallation). The mainboard is only currently not yet available in the store, I think the regular PinePhone's Braveheart Edition didn't have replacement parts and mainboards in the store back then either and I assume it makes sense for Pine not to produce a large amount of replacement mainboards if a new hardware revision is possible for the next batch. The mainboard itself will probably be however a large part of the overall phone price.
Could you clarify the question? I have trouble understanding it. The mainboards as whole can be replaced individually and from what I know should be in the store quite soon. Replacing the SIM card slot individually is not advised, as it is quite difficult for soldering experts.
  No phone call audio, logs posted, modem can't init audio? biketool 12 5,491 12-22-2025, 05:09 PM
  slight bumps causing phone to turn off. JadenSki 2 1,834 11-11-2025, 02:05 PM
Last Post: JadenSki
  Fix to Sim Adapter Problem dorkydev 2 3,047 01-08-2025, 07:33 PM
Last Post: chaylengordon
  How to remove the sim card liberty1234 7 13,319 07-17-2024, 09:57 AM
Last Post: Blackheart
  Anyone yet received replacement sim/sd card holder tckosvic 19 26,022 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 9,985 03-26-2023, 02:55 AM
Last Post: tux_life
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 3,738 03-24-2023, 03:12 PM
Last Post: fxc
  Question on the keyboard battery with phone knoxvilles_joker 0 3,211 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  PinePhone Pro Motherboard with sim card holder tckosvic 1 4,061 08-22-2022, 06:42 PM
  Pine Store : Pine phone Pro Parts ? bcnaz 7 11,330 04-08-2022, 09:45 PM
Last Post: bcnaz
