Fix to Sim Adapter Problem
What are people using? Just a clear piece of tape over the backside of the SIM adapter to catch it from dropping in any further? Or is there another adapter with a transparent portion?
This is I think the second SIM tray that has died on me.
(12-24-2024, 10:16 AM)dorkydev Wrote: What are people using? Just a clear piece of tape over the backside of the SIM adapter to catch it from dropping in any further? Or is there another adapter with a transparent portion?
i usually use plastic sim card frames which come with a sim cards from operator. in this case nano to micro. those can be chopped and used. i haven't had issues.
do not put frame alone to tray !
pp pro uses nano sim, which simplifies things for me. although older ones used micro-sim.
i use adapters for pp regulars.
Some users have modified their SIM adapters by attaching a small, transparent piece of geometry dash plastic or tape to the back, allowing visibility while providing extra thickness to prevent the adapter from falling through.
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 19,050 06-15-2022, 02:32 AM
Last Post: fxc
  Battery discharge problem g4mba5 16 21,215 02-01-2022, 03:30 AM
Last Post: bcnaz
