UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
(05-24-2022, 05:07 PM)fdriodIOS Wrote: I flashed the image with Balena but Balena said the image was not an OS image.
Odd, I recently used Balena Etcher (on Mac OS) to write the image to a card and it gave me no trouble. Did you extract the compressed image with zstd first?  Does the checksum match?
I recently used Balena Etcher (on Windows) to write the image to a card and it gave me no trouble. I did extract the compressed image with zstd or another tool.
(06-03-2021, 06:43 AM)megous Wrote: Let me know if there are any major issues. For the next release I'll hopefully get to adding some menu option for booting into a multi-boot management UI, that will allow for modifications (like resetting the distros to original state, or kernel updates, or modifying the boot menu and removing the unwanted distros, or migrating to eMMC, and things like that).
It would be an interesting way to install a distro to pinephone. Load up SD card with multi-boot image, try the distros, and then just select the one you like and it would be installed to eMMC (either in the original form with u-boot and distro kernel, or using p-boot and my kernel and without losing any changes).
Or you could just drop the distros you don't like from SD card by deleting them from the menu and continue using multi-boot image as is.
If distros use home directory to store user settings/data, it may even be possible to share a single home directory (btrfs subvolume) across all the distros. So theoretically it would not matter which posh based distro you'd boot, it would contain the same settings and data. Would be nice to not have to re-do the wifi configuration for each distro, etc. In reality it may not work that well, because I guess some distros store settings in /etc, but it might be interesting to try.
First, thanks for what you did so far, or else I wouldn't be here - I'd die of how much my friends would mock me for having a phone which doesn't quite work, as the original Manjaro Plasma I got had serious issues, like losing modem frequently. Now it boots to a command prompt without a keyboard, so I can't even log in to it, my eMMC is practically unusable.
However, the distros work fine, at least Mobian did until it commited suicide by update. I'm now using Manjaro Phosh, with which I'm rather satisfied, except one remaining issue - ring doesn't wake the phone up, nor does SMS nor anything except that silly little wakeup app.
I came to this thread looking for a way to flash my working distro to eMMC, and so found this message of yours. Lovely ideas, exactly the things I'd like to do Smile. Seeing how your attention has shifted to other Pine hardware, I guess this was just another neat idea that stayed on the back burner forever. But doesn't hurt to check, so... did you do anything about this? Well, since my version, which is of 17-aug-2022.
  Pinephone visibly losing power while plugged in Hiraghm 10 10,270 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,152 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 89,224 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,181 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,225 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,864 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,551 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,188 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,571 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,052 10-21-2025, 12:12 PM
Last Post: Richy_T
