Cannot find "-" on the pinephone keyboard
I have tried all the left Shift + Fn + all the F1-F10 keys and cannot find a "-". The use of F5 or F6 produce the "~". The use of F7 or F9 produce the "_". The use of the F8 or F10 produce the "+". Finally, the use of F1 or F2 produce the "|". Everything else on the keyboard appears to work as well as the charging and disconnect of my pinephone from charging using the keyboard battery. Am I overlooking something and why is there redundancy in some of the symbols produced using the F keys? Any help is appreciated. Thanks
For me the minus key is under F7.
You might need to change the keyboard layout.
I think you can find the current configuration by going
# xkbcomp $DISPLAY output.xkb
(https://wiki.archlinux.org/title/X_keyboard_extension)
Look for the section that controls the number row, for me it's like
xkb_symbols "(unnamed)" {
    name[group1]="English (US)";
    key  <ESC> {         [          Escape ] };
    key <AE01> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               1,          exclam,             bar,        NoSymbol ]
    key <AE02> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               2,              at,       backslash,        NoSymbol
    key <AE07> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               7,       ampersand,           minus,        NoSymbol ]
Maybe your layout doesn't define the third level of keys. At least on PPP it was recently broken on Manjaro.
If that's the problem there is an updated keyboard map here
https://codeberg.org/HazardChem/PinePhon...h/main/tty
This is what I did for Manjaro plasma on PPP
https://forum.pine64.org/showthread.php?tid=16640
Thank you for your suggestions. Currently running Mobian, have to see if your suggestions are applicable.
(05-20-2022, 11:40 AM)gilwood Wrote: I have tried all the left Shift + Fn + all the F1-F10 keys and cannot find a "-". The use of F5 or F6 produce the "~". The use of F7 or F9 produce the "_". The use of the F8 or F10 produce the "+". Finally, the use of F1 or F2 produce the "|". Everything else on the keyboard appears to work as well as the charging and disconnect of my pinephone from charging using the keyboard battery. Am I overlooking something and why is there redundancy in some of the symbols produced using the F keys? Any help is appreciated. Thanks
I described this problem in post 1 and post 5 of this thread,
https://forum.pine64.org/showthread.php?tid=15787
I use ManjaroARM, but I think this is the kernel keyboard driver, not specific to an OS. I show the two layers of symbols you get with Fn-Num Key and Shift-Fn-Numkey and their redundancies.
The fix for this is installing the userspace driver which gets you what is printed on the keys and f-Keys using the Pine key + num key. A method for doing this for Mobian is described here:
https://forum.pine64.org/showthread.php?tid=16153
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,444 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,209 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,972 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,706 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 26,985 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,422 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,180 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,402 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,261 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,137 07-04-2024, 05:40 AM
