Burning Android Image Hell
1st attempt at resizing the partition broke the installation Wink
(05-26-2016, 02:09 PM)Major_Sarcasm Wrote: 1st attempt at resizing the partition broke the installation Wink
yea, i too had no luck either
(05-25-2016, 12:55 PM)Luke Wrote:
(05-25-2016, 12:32 PM)Major_Sarcasm Wrote: Downloading the 8GB image now. I'll try resizing it with a partition tool that I have.
I had issues with gparted - just letting you know. Come back and report if you got it to work
I tried with PhoenixCard (no DD images for the build I wanted) on two different Windows computers with built in SD card readers (using microSD card adapter) - both failed.   Major PITA - why can't you release a "dd" image?  I don't run Windows, so I have to do this sh!t at work - or borrow one of my daughters' Windows machines....
So I got a dinky little plastic microSD USB card reader I've had for years - put it in Windows (I fenestrated it) and PhoenixCard burn worked...
But still waiting for a ROOTY-TOOT-TOOT'ed (some people on this forum get a bit sooky-la-la when I the use of the "F__K" word - but in Australian English the word "root" means the same thing as "f__k" :-) ) DD Android image (Lollipop or Marshmallow - I don't give a "root") supporting the Pine supplied LCD Touchpanel...
Android without root is next to useless for me...
Did you try this: http://forum.pine64.org/showthread.php?tid=548 ?
Saved me a lot of nerves...
Okay, I had the exact same problem as your first description.
My solution was to downloade "Android PhoenixCard Image Release 20160216"
link: http://files.pine64.org/os/android/Pinea...160216.zip
burn it with "Allwinner PheonixCard Bootable SD-Card Creato"
link: https://drive.google.com/file/d/0B0cEs0l...U1NFk/view
When I burned the image i followed this tutorial:
https://www.youtube.com/watch?v=TjJ62s5DxPc
I did however get an error message (sorry, don't have a screenshot) but I tried to use the card in the pine anyway and it worked Big Grin
I think the pine took 5 min or so to boot.
All the files can also be found at:
http://wiki.pine64.org/index.php/Pine_A6...re_Release
  Need help compiling android for pine a64 + YeeticusMaximus22 1 969 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 559,133 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 45,349 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,836 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,337 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,648 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,358 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,913 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 376,891 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,650 02-26-2019, 11:58 AM
Last Post: Twistedx
