Trying the camera switch on my PinePhone
Since everything tried so on my PinePhone was working and I had just completed my weekly update to Mobian I thought it might be useful to check out the dip switches and disable the front-facing camera. Clicked down switch 5, which should have disabled the front-facing camera, only. Rebooted the phone and when I brought up the camera app nothing happened except showing the background wallpaper. It appeared as if the camera app was totally disabled. The good news was that when I returned the switch to the off position and rebooted the phone the cameras both worked perfectly. This was contrary to some reports I had read which had described a total reinstall of the OS to make the return settings work. Yaaa.
Am I missing something on setting the dip switches or is there still work in progress? Any comments or assistance is always appreciated. Thanks
According to the schematic the camera switches disconnect the processor gpio lines that control each camera module's power pin so the processor can't power on the camera module. I don't know if the camera app and/or drivers allow for this possibility, or try to enable a camera and get confused if it fails to respond.
(01-24-2022, 05:17 PM)gilwood Wrote: Clicked down switch 5, which should have disabled the front-facing camera, only. Rebooted the phone and when I brought up the camera app nothing happened except showing the background wallpaper. It appeared as if the camera app was totally disabled.
Run megapixels in terminal and see what it says. I think the app is just buggy. I have the front camera always disabled and sometimes megapixels will work and something it will crash on start.
But maybe this isn't megapixels's fault, because I had similar results when I tried using the camera with opencv in python. Maybe it's the drivers like @wibble said.
The good news is that with every update to Mobian something gets fixed. Hopefully, there are not many selfie lovers over those that don't want to run the risk of the camera watching them so disabling will be fixed. Thanks for the comments.
(01-26-2022, 07:25 PM)gilwood Wrote: The good news is that with every update to Mobian something gets fixed. Hopefully, there are not many selfie lovers over those that don't want to run the risk of the camera watching them so disabling will be fixed. Thanks for the comments.
Megapixels still segfaults when one of the cameras is turned off.  This seems to have been fixed upstream.
  Mobian image for the PinePhone Korfou 2 659 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 57,314 12-24-2025, 12:11 AM
  camera not usable with trixie? JChdeL 0 555 12-05-2025, 01:45 AM
Last Post: JChdeL
  Switching cameras on PPpro Camera app biketool 0 632 11-11-2025, 10:44 AM
  cryptocurrency on mobian/pinephone biketool 35 67,460 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 316,458 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 3,286 06-07-2025, 03:19 PM
  New camera app gnome-snapshot working on trixie? vusra 4 3,846 04-11-2025, 02:53 AM
Last Post: vusra
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 6,617 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 2,968 01-02-2025, 12:47 PM
Last Post: zetabeta
