No underscore on pinephone keyboard
Running a community edition pinephone using mobian bookworm on my new keyboard. Everything appears to be working with the exception of having an underscore character. Cannot type name_pine in any app. Really need access to this character for terminal. Any ideas or comments are appreciated. Thanks
At least with the userspace driver hitting Fn-9 yields the underscore. (Not sure about the kernel driver, have not used that in a while now.)
I faced the same problem at first.
Digging through Megi's code led me to the answer.
Just holding Fn+9 isn't enough, the right key combination is:
Fn+(Left)Shift+9.
Let me know if this works out for you as well.
Greetings Jasper
It worked. Thanks
I will post as solved.
  Recycling pinephone as home server mdk 3 407 11-12-2025, 11:18 AM
  Pinephone + Keyboard for sale, little use ruemoo 10 5,858 10-07-2025, 07:36 PM
Last Post: PinePhoneProUser
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 2 5,896 07-09-2025, 02:04 PM
Last Post: georgegohl888
  Modem Issues with the Pinephone Temmie19 5 3,829 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 2,652 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,025 03-25-2025, 08:51 PM
  Pinephone - broken power button rorus 13 17,827 12-16-2024, 08:32 PM
  various tricks to open the pinephone shengchieh 3 3,960 09-16-2024, 03:42 AM
  Updated Physical Keyboard? jakfish 10 9,030 07-04-2024, 10:59 PM
Last Post: Peter Gamma
  my pinephone melted norayr 6 5,497 04-04-2024, 07:22 PM
