PSU for keyboard case battery PD+QC
OK I have a charger with a USB-C to USB-C cable. The outlet on the charger says "PD+QC" and is rated 5Vx3A which I want to use to charge the keyboard case battery, but also lists other voltages and currents. The voltages and currents for QC are different again.
I have read around a bit, PD is OK for the PinePhone keyboard case ( https://xnux.eu/pinephone-keyboard/faq.html#chargers ). The QC appears to be a Qualcomm "standard" that only is activated when it encounters one of their chipsets that has QC activated https://en.wikipedia.org/wiki/Quick_Charge
So am I correct in thinking that although the outlet is labelled "PD+QC" that it will only present the PD supply to the PinePhone? Also that the correct voltage will be set for the PinePhone?
(01-29-2022, 08:06 AM)grump_fiddle_reinstall Wrote: OK I have a charger with a USB-C to USB-C cable. The outlet on the charger says "PD+QC" and is rated 5Vx3A which I want to use to charge the keyboard case battery, but also lists other voltages and currents. The voltages and currents for QC are different again.
Your assumption is correct, only PD supply to PinePhone and 5V3A will be selected.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 3,600 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,155 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 1,970 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 8,226 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 23,580 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,551 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 3,589 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 4,755 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 19,495 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,432 07-04-2024, 07:32 AM
