05-27-2016, 02:02 AM
How not agree with you! PhoenixCard is a crap, can't really understand why a development board that can be used with linux and android should use a proprietary tool to flash OS images.
Not possible to make a bootable SD
05-27-2016, 02:11 AM
Hi Outlaw,
I understand you're not lucky with the situation, but please do not use infect my topic with your swearing! Your post doesn't bring me any closer to a solution. If you want to swear and complain, please open your own topic. Regards, Mischa
05-27-2016, 02:25 AM
(This post was last modified: 05-27-2016, 03:43 AM by UnixOutlaw.)
Well there ya go! Bit of a hunt around - tried a teeny little USB MicroSD reader - and it worked (from Phoenixcard writer in Windows) !
Got it booting (or seeming to boot) now with Android on the Pine supplied TouchPanel... Screen flashed Android 64 bit about 10 times - now there's like 800 tiny white vertical lines across the screen.... does that mean anything? -------------------------------------------------- edit : got it booted into Android now... not pretty... Is this my only option if I want to use the 7" Touchpanel? If I'd known there was no Linux support for the Touchpanel - I wouldn't have bought it with my 2 x Pine 2 GB boards... This project was always advertised as an Android AND Linux 64 bit platform... sorry Mischa if you're offended by my use of coarse language - you probably won't much like my avatar picture either... |
| How to Make a Pine with Android 7.0 Stay on All the Time? | Bob123456789 | 3 | 8,069 |
04-05-2017, 01:12 PM Last Post: Bob123456789 |
| Creating bootable SD card on Mac OS X | colinj | 13 | 34,711 |
01-24-2017, 03:03 AM Last Post: MarkHaysHarris777 |
| anyone make pine64 lcd hdmi work simultaneously | bokeer | 4 | 11,174 |
12-11-2016, 05:57 PM Last Post: Luke |
| how do you make Android image for LCD Panel | nath16 | 3 | 8,047 |
06-09-2016, 07:23 PM Last Post: tllim |
| Bootable SD card with android image | mcs_dodo | 7 | 13,375 |
05-18-2016, 09:38 AM Last Post: tllim |
| Steps to create Android bootable micro-SD card | khgoh | 0 | 5,810 |
01-07-2016, 07:56 PM Last Post: khgoh |
