Is there a way to increase the battery life of the PinePhone?
(12-24-2021, 06:12 AM)Avisando Wrote: I would like to know if there is a way to increase the battery life of the PinePhone as it is very difficult to last all day (even when doing almost nothing).
I have already :
- disable wifi/4G/bluetooth
- disable automatic rotation
- adjust the brightness to the strict minimum
- close background applications
And it is enough that during the day I receive two or three calls of barely a minute and that I take ten photos so that I find myself at less than 10% after ten hours.
So if someone would have a solution to this problem I would be grateful for it.
Thanks in advance Smile
The new keyboard is an available option now, I am using one now,
It has a double sized battery in it, added to the phones battery, it gives triple the current runtime.
It is a bit larger package this way, it is now sort of a mini laptop.
My first post using the keyboard.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I’m on Mobian, had the phone out for 10 hours (work), made a dozen or so calls and email, still at 50%; had really bad battery life with Manjaro.
PinePhone, Pinebook Pro & PineTab2 owner.
(01-20-2022, 09:06 AM)dachalife Wrote: I’m on Mobian, had the phone out for 10 hours (work), made a dozen or so calls and email, still at 50%; had really bad battery life with Manjaro.
Interesting, I think I'll try Mobian again these days : )
(01-19-2022, 10:51 PM)bcnaz Wrote: The new keyboard is an available option now, I am using one now,
It is a bit larger package this way, it is now sort of a min laptop.
Yeah I saw that and it's pretty awesome.
To make calls the keyboard is not too disturbing?
Just got my keyboard yesterday afternoon,  and I am using it on one of my "test" phones, I have not made a call on it yet.
I am planning on trying that with an earphone,  the onboard microphone should work ok.
Perhaps speaker phone will suffice ?  The echo seems to almost disappear if you turn down the microphone volume.
Would only need an ear phone for private conversations.
But yes, putting a keyboard to your ear does not sound comfortable.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-20-2022, 06:28 PM)bcnaz Wrote: Just got my keyboard yesterday afternoon,  and I am using it on one of my "test" phones, I have not made a call on it yet.
Thanks for these informations  Smile
I frequently use a wired earphone headset that has a built-in microphone with the Pinephone since otherwise it can be difficult to hear in a noisy environment.
The only issue I've found is that for the microphone to work you need to plug the headset in while the first call is in progress. (If you plug it in before the first call, the microphone does not work. Not sure why. It's kind of bizarre.) After this is done with the initial call it seems to work OK for subsequent calls as long as the headset stays plugged in. I don't have my keyboard yet but suspect that this will be the best way to use the phone+keyboard combo.
Hopefully at some point we'll have bluetooth audio working for calls.
Of interest,
While I was on the forum yesterday using my new keyboard on my phone, I started by using my cellular data and browsed the forum for quite some time,
but when I tried to log-in to the forum to respond to a post, it refused to let me log-in.
when I swapped from cellular data to wifi, I logged-in on the first try. ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-21-2022, 11:18 PM)bcnaz Wrote: Of interest,
Keyboard Layout wrong?
Test your Layout within a Textfile?
APN Settings ok?
Ciao
Walter
That was one of my test phones with the new keyboard attached.
I will try again later when I remove the keyboard,  and see what happens.
Beta hardware + Beta software =   Huh    or     Big Grin
** (The APN is correct, -- I was using cell data to browse the web and forum when I could not log into the forum.)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Does PinePhone support long-term battery health optimization? roseblack 3 400 Yesterday, 09:30 PM
Last Post: evilbunny
  iso pinephone for sale (USA) elwoodb25 0 3,473 09-24-2025, 09:25 PM
Last Post: elwoodb25
  Why projects like PinePhone matter – feedback and encouragement Gary2003 13 16,691 09-16-2025, 01:13 PM
Last Post: Gary2003
  Can use PlayStation on Pinephone? willharper 7 8,310 09-13-2025, 12:30 AM
Last Post: ChaiLetters
  Pinephone Pro Neural Processing Unit biketool 1 5,001 09-01-2025, 02:05 AM
  Want to buy second hand PinePhone 3G version rudi.timmermans 2 4,519 08-31-2025, 07:18 AM
Last Post: Fish
  Pinephone Pro not in store? bubulux20c 1 2,827 08-08-2025, 02:12 AM
Last Post: P. Siera
  PinePhone Pro EU no warranty P. Siera 0 2,379 07-21-2025, 12:08 AM
Last Post: P. Siera
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 17,282 07-18-2025, 04:24 PM
Last Post: dchang0
  Pinephone visibly losing power while plugged in Hiraghm 2 3,605 05-23-2025, 12:30 PM
