flatpack on mobian
Does anyone know how to install flatpack on mobian? It's not findable in the "software" app, and 'apt-get install flatpack' returns that it can't find the package. I found one forum thread which suggested that flatpack is available through the unstable repository. If this is true, is there a way to switch to unable for just this package?
It's flatpak, not flatpack. Maybe that helps :-)
Ah, indeed it is. In fact, it's already installed. Thanks! I'll mark this thread as 'solved'.
Does anyone know how to uninstall flatpak on Mobian Bookworm? It seems to be installed by default, but I don't want to install software through anything else than apt, because I don't trust it. When I try to remove flatpak it also wants to remove packages like mobian-phosh.
(01-19-2022, 10:20 AM)beta-user Wrote: Does anyone know how to uninstall flatpak on Mobian Bookworm? It seems to be installed by default, but I don't want to install software through anything else than apt, because I don't trust it. When I try to remove flatpak it also wants to remove packages like mobian-phosh.
It's more important then to remove any flatpak installed + any repository. Once you do that, and if you never download and manually install a flatpak, you won't accidentally install any.
I haven't installed anything through flatpak. I don't think I've used it at all and it seems that it's included by default in Mobian and required by phosh. I don't understand why. Is phosh installed and updated through flatpak? I would have to check on a fresh install to be sure.
(01-20-2022, 05:38 AM)beta-user Wrote: I haven't installed anything through flatpak. I don't think I've used it at all and it seems that it's included by default in Mobian and required by phosh. I don't understand why. Is phosh installed and updated through flatpak? I would have to check on a fresh install to be sure.
Because Phosh as originally envisioned by Purism, would have all end-user applications distributed as Flatpaks. And I suppose for Mobian, flatpak is installed by default to avoid breaking that, and because it's useful for many people -- for a while, for example, Fractal (a Matrix client) was only distributed as a flatpak (something I think the Debian team has remediated Wink )
(01-25-2022, 09:39 PM)pajux Wrote: Because Phosh as originally envisioned by Purism, would have all end-user applications distributed as Flatpaks. And I suppose for Mobian, flatpak is installed by default to avoid breaking that, and because it's useful for many people -- for a while, for example, Fractal (a Matrix client) was only distributed as a flatpak (something I think the Debian team has remediated Wink )
That's pretty weird! For me it's a big flaw. Flatpak is a less secure alternative to apt. I checked the phosh package in Debian and I don't see flatpak as a dependency. So either I missed it or it must be possible to use Phosh without Flatpak.
https://wiki.mobian-project.org/doku.php...ll-flatpak
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 52,390 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 35 64,533 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 31,469 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,505 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 301,251 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,265 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,016 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,540 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,430 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,532 01-15-2025, 08:08 PM
