New Keyboard Questions
(01-13-2022, 10:09 AM)ragreenburg Wrote: I think the answer is yes. I don't know the knowhow of it but I think it basically just checks if the keyboard is attached on boot then goes from there. I think you can still charge the phone without having to reboot it but to use the keyboard you need to turn it off then on again. Easy workaround, don't ever take the keyboard off...
I haven't checked (nor I have received my keyboard yet) but I would think if it checks the keyboard at boot time then it should be booted while the keyboard is attached and it may be removed / reinserted later so I would think it may work. Smile
However, it may happen it periodically checks if it is attached but then I would ask why it does not check for it periodically on absence. Smile
Anyway, I would also think related kernel module and / or user application may be started later so connection should be possible also on a working system but its automatism is what is missing. Smile
You very well might be right, I am know they said it has to be on during boot and my keyboard is still in china so I can't test either.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,705 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,494 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,115 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 27,488 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,531 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,798 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,366 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,223 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,064 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 23,844 06-29-2024, 04:09 AM
