Best OS where most of the things work?
(12-07-2021, 05:19 AM)biketool Wrote: That and at least Mobian on Pinephone needs better battery life.
It really, Really REALLY needs better battery life. Running Bookworm, I unplugged the phone at 5:30am. It rode in my pocket until about 10am, and the battery was almost completely discharged. That STINKS!
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
I suggest you put your PinePhone in crust mode.
So:
systemctl suspend -i
母語は日本語ですが、英語も喋れます(ry
(12-08-2021, 10:17 PM)ryo Wrote: I suggest you put your PinePhone in crust mode.
So:
Ryo, that suspends the machine, just leaves the modem awake enough to receive calls and texts, right?
Edited to add:
It suspends, then pops back awake in a few seconds, to the lock screen.
(12-09-2021, 06:44 PM)nelstomlinson Wrote: Ryo, that suspends the machine, just leaves the modem awake enough to receive calls and texts, right?
Correct.
(12-09-2021, 06:44 PM)nelstomlinson Wrote: It suspends, then pops back awake in a few seconds, to the lock screen.
Happens sometimes if you put it to crust mode and immediately put it in your pocket.
Best is to wait a couple of seconds before doing that, and make sure you won't touch the power button, since that's the only input device that remains enabled while under crust.
  Should HDMI output work immediately? Richy_T 0 750 10-20-2025, 05:06 PM
Last Post: Richy_T
  PureTalk work with Pinephone? car46999 6 8,062 01-30-2023, 12:05 AM
Last Post: car46999
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 2,721 05-21-2022, 03:03 PM
Last Post: zetabeta
  SD nonfunctional, how is support supposed to work? slomobile 6 7,885 01-18-2022, 07:02 PM
Last Post: slomobile
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 3,116 11-07-2021, 10:15 AM
Last Post: beta-user
  Lets discuss the GPS. Who has got it to work? AwHereWeGoAgain 8 11,504 09-17-2021, 01:29 PM
Last Post: KNERD
  What OS will actually work with phone calls? Nutmeg 16 21,953 08-07-2021, 11:01 AM
Last Post: mouffa
  Will the Pinephone work with Vodafone in Romania? MirceaKitsune 2 4,936 05-30-2021, 09:42 AM
Last Post: MirceaKitsune
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 2,693 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  With what image(s) does phoning fully work? LinAdmin2 13 21,942 10-04-2020, 09:06 PM
Last Post: SwordfishII
