slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64)
start testing
U-Boot SPL board init U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256+ OK ## Checking uboot 0x00a00000 ... sha256+ OK ## Checking fdt 0x00b21290 ... sha256+ OK ## Checking atf-2 0xfdcc9000 ... sha256+ OK ## Checking atf-3 0xfdcd0000 ... sha256+ OK ## Checking optee 0x08400000 ... sha256+ OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 257.955 ms INFO:    Preloader serial: 2 NOTICE:  BL31: v2.3():v2.3-135-gcda1658bc-dirty:xsf NOTICE:  BL31: Built : 19:32:20, Jun  2 2021 INFO:    GICv3 without legacy support detected. INFO:    ARM GICv3 driver initialized in EL3 INFO:    pmu v1 is valid INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    BL31: Initializing runtime services INFO:    BL31: Initializing BL32 I/TC: I/TC: Start rockchip platform init I/TC: Rockchip release version: 1.0 I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May  7 01:52:27 UTC 2021 aarch64 I/TC: Initialized INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0xa00000 INFO:    SPSR = 0x3c9 U-Boot 2017.09 (Jun 15 2021 - 16:55:48 +0000) Model: Pine64 RK3566 Quartz64 Board PreSerial: 2, raw, 0xfe660000 DRAM:  7.7 GiB Sysmem: init Relocation Offset: ed39f000, fdt: eb9f9f78 no mmc device at slot 1 dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 50Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition No resource partition Failed to load DTB Failed to get kernel dtb, ret=-19 io-domain: OK ** Unable to use mmc 1:3 for loading the env ** Using default environment Model: Pine64 RK3566 Quartz64 Board rockchip_set_serialno: could not find efuse/otp device CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)   apll 816000 KHz   dpll 528000 KHz   gpll 1188000 KHz   cpll 1000000 KHz   npll 24000 KHz   vpll 24000 KHz   hpll 24000 KHz   ppll 100000 KHz   armclk 816000 KHz   aclk_bus 150000 KHz   pclk_bus 50000 KHz   aclk_top_high 300000 KHz   aclk_top_low 200000 KHz   hclk_top 150000 KHz   pclk_top 50000 KHz   aclk_perimid 300000 KHz   hclk_perimid 150000 KHz   pclk_pmu 50000 KHz Net:  clk_get_by_name(master_bus) failed: -22eqos_probe_resources() failed: -22No ethernet found. Hit key to stop autoboot('CTRL+C'):  0 ## Booting FIT Image FIT: No boot partition FIT: No FIT image Could not find misc partition ANDROID: reboot reason: "(none)" optee api revision: 2.0 TEEC: Waring: Could not find security partition Not AVB images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. switch to partitions #0, OK mmc1 is current device Scanning mmc 1:2... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 388 bytes read in 3 ms (126 KiB/s) 1:      Slarm64 Retrieving file: /Image reading /Image 29239808 bytes read in 2429 ms (11.5 MiB/s) append: root=/dev/mmcblk0p3 ro earlycon=uart8250,mmio32,0xfe660000 console=tty1 console=ttyS2,1500000n8 verbosity=8 Retrieving file: /dtb/rk3566-quartz64a.dtb reading /dtb/rk3566-quartz64a.dtb 75961 bytes read in 11 ms (6.6 MiB/s) Fdt Ramdisk skip relocation ## Flattened Device Tree blob at 0x0a100000   Booting using the fdt blob at 0x0a100000   'reserved-memory' ramoops@110000: addr=110000 size=f0000   Using Device Tree in place at 000000000a100000, end 000000000a1158b8 Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Total: 2824.673 ms Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux version 5.13.0-rc4-next-20210603 (root@slarm64-dev) (gcc (GCC) 10.3.0, GNU ld version 2.36.1-slack15) #1 SMP PREEMPT Fri Jul 16 22:40:47 UTC 2021 [    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board [    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '') [    0.000000] printk: bootconsole [uart8250] enabled [    0.000000] efi: UEFI not found. [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [    0.000000] Reserved memory: created CMA memory pool at 0x00000000a0000000, size 256 MiB [    0.000000] OF: reserved mem: initialized node linux,cma@80000000, compatible id shared-dma-pool [    0.000000] Zone ranges: [    0.000000]  DMA      [mem 0x0000000000200000-0x00000000ffffffff] [    0.000000]  DMA32    empty [    0.000000]  Normal  [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Movable zone start for each node [    0.000000] Early memory node ranges [    0.000000]  node  0: [mem 0x0000000000200000-0x00000000083fffff] [    0.000000]  node  0: [mem 0x0000000009400000-0x00000000efffffff] [    0.000000]  node  0: [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.1 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: Trusted OS migration not required [    0.000000] psci: SMC Calling Convention v1.2 [    0.000000] percpu: Embedded 24 pages/cpu s57432 r8192 d32680 u98304 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] CPU features: detected: Virtualization Host Extensions [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [    0.000000] alternatives: patching kernel code [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1995336 [    0.000000] Kernel command line: root=/dev/mmcblk0p3 ro earlycon=uart8250,mmio32,0xfe660000 console=tty1 console=ttyS2,1500000n8 verbosity=8 [    0.000000] Unknown command line parameters: verbosity=8 [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [    0.000000] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB) [    0.000000] Memory: 7585716K/8108032K available (17216K kernel code, 2058K rwdata, 6144K rodata, 3008K init, 1003K bss, 260172K reserved, 262144K cma-reserved) [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x180 with crng_init=0 [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] rcu: Preemptible hierarchical RCU implementation. [    0.000000] rcu:    RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [    0.000000]  Trampoline variant of Tasks RCU enabled. [    0.000000]  Tracing variant of Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 320 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] Root IRQ handler: gic_handle_irq [    0.000000] GICv3: 16 PPIs implemented [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    0.000000] ITS [mem 0xfd440000-0xfd45ffff] [    0.000000] GIC: enabling workaround for ITS: Rockchip RK3568 force no_local_cache [    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @410000 (indirect, esz 8, psz 64K, shr 0) [    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @420000 (flat, esz 2, psz 64K, shr 0) [    0.000000] ITS: using cache flushing for cmd queue [    0.000000] ITS ALLOCATE PROP WORKAROUND [    0.000000] GICv3: using LPI property table @0x0000000000430000 [    0.000000] GIC: using cache flushing for LPI property table [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000000440000 [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001628] Console: colour dummy device 80x25 [    0.002777] printk: console [tty1] enabled [    0.003224] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [    0.004223] pid_max: default: 32768 minimum: 301 [    0.004829] LSM: Security Framework initializing [    0.005353] SELinux:  Initializing. [    0.005914] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.006694] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.009938] rcu: Hierarchical SRCU implementation. [    0.011125] Platform MSI: interrupt-controller@fd440000 domain created [    0.012133] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created [    0.014732] EFI services will not be available. [    0.015582] smp: Bringing up secondary CPUs ... [    0.016820] Detected VIPT I-cache on CPU1 [    0.016867] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    0.016890] GICv3: CPU1: using allocated LPI pending table @0x0000000000450000 [    0.016959] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    0.017814] Detected VIPT I-cache on CPU2 [    0.017855] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    0.017876] GICv3: CPU2: using allocated LPI pending table @0x0000000000460000 [    0.017926] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    0.018806] Detected VIPT I-cache on CPU3 [    0.018843] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [    0.018863] GICv3: CPU3: using allocated LPI pending table @0x0000000000470000 [    0.018906] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [    0.019035] smp: Brought up 1 node, 4 CPUs [    0.026489] SMP: Total of 4 processors activated. [    0.026942] CPU features: detected: 32-bit EL0 Support [    0.027435] CPU features: detected: 32-bit EL1 Support [    0.027927] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [    0.028774] CPU features: detected: Common not Private translations [    0.029378] CPU features: detected: CRC32 instructions [    0.029873] CPU features: detected: RCpc load-acquire (LDAPR) [    0.030424] CPU features: detected: LSE atomic instructions [    0.030956] CPU features: detected: Privileged Access Never [    0.031488] CPU features: detected: RAS Extension Support [    0.032005] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [    0.068239] CPU: All CPU(s) started at EL2 [    0.072128] devtmpfs: initialized [    0.089752] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [    0.090732] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [    0.101620] pinctrl core: initialized pinctrl subsystem [    0.102993] DMI not present or invalid. [    0.103954] NET: Registered protocol family 16 [    0.106193] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [    0.107153] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [    0.108320] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [    0.109233] audit: initializing netlink subsys (disabled) [    0.109991] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1 [    0.112056] thermal_sys: Registered thermal governor 'step_wise' [    0.112465] cpuidle: using governor ladder [    0.113468] cpuidle: using governor menu [    0.114102] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.114919] ASID allocator initialised with 65536 entries [    0.116853] Serial: AMBA PL011 UART driver [    0.118315] printk: console [ramoops-1] enabled [    0.119099] pstore: Registered ramoops as persistent store backend [    0.119701] ramoops: using 0xf0000@0x110000, ecc: 0 [    0.134355] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop [    0.152161] rockchip-gpio fdd60000.gpio0: probed /pinctrl/gpio0@fdd60000 [    0.153670] rockchip-gpio fe740000.gpio1: probed /pinctrl/gpio1@fe740000 [    0.155016] rockchip-gpio fe750000.gpio2: probed /pinctrl/gpio2@fe750000 [    0.156329] rockchip-gpio fe760000.gpio3: probed /pinctrl/gpio3@fe760000 [    0.157640] rockchip-gpio fe770000.gpio4: probed /pinctrl/gpio4@fe770000 [    0.175308] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [    0.175987] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [    0.176632] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [    0.177276] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [    0.182034] cryptd: max_cpu_qlen set to 1000 [    0.359984] raid6: neonx8  gen()  1411 MB/s [    0.530116] raid6: neonx8  xor()  1109 MB/s [    0.700257] raid6: neonx4  gen()  1441 MB/s [    0.870371] raid6: neonx4  xor()  1099 MB/s [    1.040475] raid6: neonx2  gen()  1342 MB/s [    1.210621] raid6: neonx2  xor()  1008 MB/s [    1.380798] raid6: neonx1  gen()  1107 MB/s [    1.550932] raid6: neonx1  xor()  811 MB/s [    1.721108] raid6: int64x8  gen()  962 MB/s [    1.891260] raid6: int64x8  xor()  514 MB/s [    2.061442] raid6: int64x4  gen()  1052 MB/s [    2.231614] raid6: int64x4  xor()  554 MB/s [    2.401690] raid6: int64x2  gen()  943 MB/s [    2.571810] raid6: int64x2  xor()  495 MB/s [    2.741913] raid6: int64x1  gen()  698 MB/s [    2.912027] raid6: int64x1  xor()  336 MB/s [    2.912448] raid6: using algorithm neonx4 gen() 1441 MB/s [    2.912970] raid6: .... xor() 1099 MB/s, rmw enabled [    2.913449] raid6: using neon recovery algorithm [    2.914164] ACPI: Interpreter disabled. [    2.917043] iommu: Default domain type: Translated [    2.917945] vgaarb: loaded [    2.918868] SCSI subsystem initialized [    2.919794] usbcore: registered new interface driver usbfs [    2.920422] usbcore: registered new interface driver hub [    2.920981] usbcore: registered new device driver usb [    2.922134] pps_core: LinuxPPS API ver. 1 registered [    2.922621] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    2.923514] PTP clock support registered [    2.923952] EDAC MC: Ver: 3.0.0 [    2.925431] FPGA manager framework [    2.925904] Advanced Linux Sound Architecture Driver Initialized. [    2.927291] NetLabel: Initializing [    2.927632] NetLabel:  domain hash size = 128 [    2.928056] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO [    2.928673] NetLabel:  unlabeled traffic allowed by default [    2.929737] clocksource: Switched to clocksource arch_sys_counter [    2.930677] VFS: Disk quotas dquot_6.6.0 [    2.931134] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    2.931920] FS-Cache: Loaded [    2.932804] pnp: PnP ACPI: disabled [    2.944752] NET: Registered protocol family 2 [    2.945636] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [    2.950653] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [    2.951647] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [    2.952925] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [    2.954617] TCP: Hash tables configured (established 65536 bind 65536) [    2.955472] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [    2.956296] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [    2.957415] NET: Registered protocol family 1 [    2.958598] RPC: Registered named UNIX socket transport module. [    2.959180] RPC: Registered udp transport module. [    2.959636] RPC: Registered tcp transport module. [    2.960141] RPC: Registered tcp NFSv4.1 backchannel transport module. [    2.960773] PCI: CLS 0 bytes, default 64 [    2.962481] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [    2.964022] kvm [1]: IPA Size Limit: 40 bits [    2.964460] kvm [1]: GICv3: no GICV resource entry [    2.964926] kvm [1]: disabling GICv2 emulation [    2.965377] kvm [1]: GIC system register CPU interface enabled [    2.966093] kvm [1]: vgic interrupt IRQ9 [    2.966878] kvm [1]: VHE mode initialized successfully [    2.977979] Initialise system trusted keyrings [    2.978686] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [    2.988138] zbud: loaded [    2.990724] squashfs: version 4.0 (2009/01/31) Phillip Lougher [    2.991711] FS-Cache: Netfs 'nfs' registered for caching [    2.992993] NFS: Registering the id_resolver key type [    2.993515] Key type id_resolver registered [    2.993924] Key type id_legacy registered [    2.994433] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [    2.995083] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [    2.995796] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [    2.998174] FS-Cache: Netfs 'cifs' registered for caching [    2.999091] Key type cifs.spnego registered [    2.999516] Key type cifs.idmap registered [    3.000335] ntfs: driver 2.1.32 [Flags: R/W]. [    3.001591] JFS: nTxBlock = 8192, nTxLock = 65536 [    3.008557] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [    3.011928] ocfs2: Registered cluster interface o2cb [    3.012670] OCFS2 User DLM kernel interface loaded [    3.015238] gfs2: GFS2 installed [    3.069083] xor: measuring software checksum speed [    3.075885]    8regs          :  1567 MB/sec [    3.081485]    32regs          :  1910 MB/sec [    3.087717]    arm64_neon      :  1694 MB/sec [    3.088141] xor: using function: 32regs (1910 MB/sec) [    3.088640] Key type asymmetric registered [    3.089039] Asymmetric key parser 'x509' registered [    3.089509] Asymmetric key parser 'pkcs8' registered [    3.090066] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [    3.090963] io scheduler mq-deadline registered [    3.091411] io scheduler kyber registered [    3.092026] io scheduler bfq registered [    3.111558] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [    3.115244] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 23, base_baud = 1500000) is a 16550A [    3.117437] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 50, base_baud = 1500000) is a 16550A [    3.119304] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 51, base_baud = 1500000) is a 16550A [    3.120464] printk: console [ttyS2] enabled [    3.120464] printk: console [ttyS2] enabled [    3.121248] printk: bootconsole [uart8250] disabled [    3.121248] printk: bootconsole [uart8250] disabled [    3.123426] Serial: AMBA driver [    3.130304] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    3.142304] brd: module loaded [    3.154324] loop: module loaded [    3.158707] libphy: Fixed MDIO Bus: probed [    3.161307] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [    3.162128] rk_gmac-dwmac fe010000.ethernet: no regulator found [    3.162674] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [    3.163311] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay. [    3.163950] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30 [    3.164502] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay. [    3.165141] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10 [    3.165697] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [    3.166300] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [    3.171867] rk_gmac-dwmac fe010000.ethernet: init for RGMII [    3.172659] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [    3.173315] rk_gmac-dwmac fe010000.ethernet:        DWMAC4/5 [    3.173786] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [    3.174460] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [    3.175133] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [    3.175765] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [    3.176426] rk_gmac-dwmac fe010000.ethernet: TSO supported [    3.176929] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [    3.177651] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [    3.178194] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width [    3.178837] rk_gmac-dwmac fe010000.ethernet: Unbalanced pm_runtime_enable! [    3.339763] libphy: stmmac: probed [    3.340090] mdio_bus stmmac-1: ethernet-phy@0 has invalid PHY address [    3.340675] mdio_bus stmmac-1: scan phy ethernet-phy at address 0 [    3.344898] VFIO - User Level meta-driver version: 0.3 [    3.355334] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    3.355977] ehci-pci: EHCI PCI platform driver [    3.356476] ehci-platform: EHCI generic platform driver [    3.359451] ehci-platform fd800000.usb: EHCI Host Controller [    3.360031] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [    3.360893] ehci-platform fd800000.usb: irq 18, io mem 0xfd800000 [    3.389769] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [    3.390604] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13 [    3.391358] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.392013] usb usb1: Product: EHCI Host Controller [    3.392456] usb usb1: Manufacturer: Linux 5.13.0-rc4-next-20210603 ehci_hcd [    3.393081] usb usb1: SerialNumber: fd800000.usb [    3.394173] hub 1-0:1.0: USB hub found [    3.394564] hub 1-0:1.0: 1 port detected [    3.397711] ehci-platform fd880000.usb: EHCI Host Controller [    3.398254] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [    3.399096] ehci-platform fd880000.usb: irq 20, io mem 0xfd880000 [    3.419797] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [    3.420623] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13 [    3.421378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.422032] usb usb2: Product: EHCI Host Controller [    3.422475] usb usb2: Manufacturer: Linux 5.13.0-rc4-next-20210603 ehci_hcd [    3.423100] usb usb2: SerialNumber: fd880000.usb [    3.424127] hub 2-0:1.0: USB hub found [    3.424516] hub 2-0:1.0: 1 port detected [    3.425680] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    3.426265] ohci-pci: OHCI PCI platform driver [    3.426775] ohci-platform: OHCI generic platform driver [    3.427623] ohci-platform fd840000.usb: Generic Platform OHCI controller [    3.428255] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [    3.429124] ohci-platform fd840000.usb: irq 19, io mem 0xfd840000 [    3.493953] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.13 [    3.494710] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.495364] usb usb3: Product: Generic Platform OHCI controller [    3.495900] usb usb3: Manufacturer: Linux 5.13.0-rc4-next-20210603 ohci_hcd [    3.496525] usb usb3: SerialNumber: fd840000.usb [    3.497564] hub 3-0:1.0: USB hub found [    3.497966] hub 3-0:1.0: 1 port detected [    3.499015] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [    3.499647] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [    3.500524] ohci-platform fd8c0000.usb: irq 21, io mem 0xfd8c0000 [    3.573968] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.13 [    3.574722] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.575376] usb usb4: Product: Generic Platform OHCI controller [    3.575912] usb usb4: Manufacturer: Linux 5.13.0-rc4-next-20210603 ohci_hcd [    3.576537] usb usb4: SerialNumber: fd8c0000.usb [    3.577569] hub 4-0:1.0: USB hub found [    3.577960] hub 4-0:1.0: 1 port detected [    3.580011] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    3.580547] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [    3.581387] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    3.582295] xhci-hcd xhci-hcd.0.auto: irq 60, io mem 0xfcc00000 [    3.583263] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13 [    3.584018] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.584673] usb usb5: Product: xHCI Host Controller [    3.585116] usb usb5: Manufacturer: Linux 5.13.0-rc4-next-20210603 xhci-hcd [    3.585743] usb usb5: SerialNumber: xhci-hcd.0.auto [    3.586809] hub 5-0:1.0: USB hub found [    3.587202] hub 5-0:1.0: 1 port detected [    3.588003] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [    3.588521] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [    3.589233] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [    3.590078] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [    3.590970] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13 [    3.591724] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.592381] usb usb6: Product: xHCI Host Controller [    3.592825] usb usb6: Manufacturer: Linux 5.13.0-rc4-next-20210603 xhci-hcd [    3.593451] usb usb6: SerialNumber: xhci-hcd.0.auto [    3.594488] hub 6-0:1.0: USB hub found [    3.594877] hub 6-0:1.0: 1 port detected [    3.595899] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    3.596425] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [    3.597257] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [    3.598164] xhci-hcd xhci-hcd.1.auto: irq 61, io mem 0xfd000000 [    3.599129] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13 [    3.599929] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.600588] usb usb7: Product: xHCI Host Controller [    3.601033] usb usb7: Manufacturer: Linux 5.13.0-rc4-next-20210603 xhci-hcd [    3.601659] usb usb7: SerialNumber: xhci-hcd.1.auto [    3.602705] hub 7-0:1.0: USB hub found [    3.603098] hub 7-0:1.0: 1 port detected [    3.603867] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [    3.604385] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [    3.605088] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [    3.605760] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [    3.606626] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13 [    3.607379] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    3.608033] usb usb8: Product: xHCI Host Controller [    3.608478] usb usb8: Manufacturer: Linux 5.13.0-rc4-next-20210603 xhci-hcd [    3.609104] usb usb8: SerialNumber: xhci-hcd.1.auto [    3.610616] hub 8-0:1.0: USB hub found [    3.611005] hub 8-0:1.0: 1 port detected [    3.612023] usbcore: registered new interface driver usb-storage [    3.612816] mousedev: PS/2 mouse device common for all mice [    3.614324] i2c /dev entries driver [    3.616876] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [    3.618022] vdd_cpu: No configuration [    3.618995] vdd_cpu: supplied by vcc3v8_sys [    3.620254] vdd_cpu: No configuration [    3.625571] rk808 0-0020: chip id: 0x8170 [    3.660318] random: fast init done [    3.669466] rk808-regulator rk808-regulator: there is no dvs0 gpio [    3.670116] rk808-regulator rk808-regulator: there is no dvs1 gpio [    3.673113] vdd_logic: supplied by vcc3v8_sys [    3.680700] vdd_gpu: supplied by vcc3v8_sys [    3.685957] vcc_ddr: Bringing 500000uV into 1100000-1100000uV [    3.690117] vcc_ddr: supplied by vcc3v8_sys [    3.695729] vcc_3v3: supplied by vcc3v8_sys [    3.701029] vcca1v8_pmu: supplied by vcc3v8_sys [    3.706705] vdda_0v9: supplied by vcc3v8_sys [    3.712031] vdda0v9_pmu: supplied by vcc3v8_sys [    3.716911] vccio_acodec: Bringing 1800000uV into 3300000-3300000uV [    3.720180] vccio_acodec: supplied by vcc3v8_sys [    3.725395] vccio_sd: supplied by vcc3v8_sys [    3.731227] vcc3v3_pmu: supplied by vcc3v8_sys [    3.736923] vcc_1v8: supplied by vcc3v8_sys [    3.741770] vcc1v8_dvp: supplied by vcc3v8_sys [    3.746175] vcc2v8_dvp: Bringing 1800000uV into 2800000-2800000uV [    3.749428] vcc2v8_dvp: supplied by vcc3v8_sys [    3.753860] boost: Bringing 4700000uV into 5000000-5000000uV [    3.757071] boost: supplied by vcc3v8_sys [    3.762225] otg_switch: supplied by vcc5v_dummy [    3.773047] sdhci: Secure Digital Host Controller Interface driver [    3.773634] sdhci: Copyright(c) Pierre Ossman [    3.774064] Synopsys Designware Multimedia Card Interface Driver [    3.775325] sdhci-pltfm: SDHCI platform and OF driver helper [    3.776399] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode. [    3.776427] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    3.777121] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller. [    3.777743] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    3.778338] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a [    3.778946] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    3.779517] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo [    3.780052] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo [    3.781814] ledtrig-cpu: registered to indicate activity on CPUs [    3.782173] dwmmc_rockchip fe2b0000.dwmmc: Got CD GPIO [    3.782960] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [    3.783808] dwmmc_rockchip fe2c0000.dwmmc: allocated mmc-pwrseq [    3.783845] hid: raw HID events driver (C) Jiri Kosina [    3.784359] mmc_host mmc2: card is non-removable. [    3.785146] usbcore: registered new interface driver usbhid [    3.785749] usbhid: USB HID core driver [    3.793085] Initializing XFRM netlink socket [    3.794257] NET: Registered protocol family 10 [    3.797062] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    3.798461] Segment Routing with IPv6 [    3.799617] NET: Registered protocol family 17 [    3.800353] Key type dns_resolver registered [    3.801234] registered taskstats version 1 [    3.801624] Loading compiled-in X.509 certificates [    3.802364] zswap: loaded using pool lzo/zbud [    3.803333] Key type ._fscrypt registered [    3.803708] Key type .fscrypt registered [    3.804067] Key type fscrypt-provisioning registered [    3.805719] Btrfs loaded, crc32c=crc32c-generic, zoned=yes [    3.806474] pstore: Using crash dump compression: deflate [    3.808370] Key type encrypted registered [    3.858644] pcie20_3v3: supplied by vcc_3v3 [    3.860156] pcie20_3v3_2: supplied by vcc_3v3 [    3.862207] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges: [    3.862921] rockchip-dw-pcie 3c0000000.pcie:      IO 0x033f700000..0x033f7fffff -> 0x007f700000 [    3.863731] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033f6fffff -> 0x0040000000 [    3.864566] rockchip-dw-pcie 3c0000000.pcie: invalid resource [    3.865107] rockchip-dw-pcie 3c0000000.pcie: iATU unroll: enabled [    3.865657] rockchip-dw-pcie 3c0000000.pcie: Detected iATU regions: 8 outbound, 8 inbound [    3.872557] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [    3.893069] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned phase to 80 [    3.893707] mmc0: new ultra high speed SDR104 SDHC card at address 0001 [    3.895232] mmcblk0: mmc0:0001 EB1QT 29.8 GiB [    3.902480]  mmcblk0: p1 p2 p3 [    3.910178] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    4.979988] rockchip-dw-pcie 3c0000000.pcie: Phy link never came up [    4.980778] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00 [    4.981417] pci_bus 0000:00: root bus resource [bus 00-0f] [    4.981923] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x7f700000-0x7f7fffff]) [    4.982784] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33f6fffff] (bus address [0x40000000-0x7f6fffff]) [    4.983755] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 [    4.984326] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [    4.985014] pci 0000:00:00.0: supports D1 D2 [    4.985408] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [    4.992069] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [    4.998336] pci 0000:00:00.0: BAR 6: assigned [mem 0x300000000-0x30000ffff pref] [    4.999024] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [    4.999665] irq: no irq domain found for legacy-interrupt-controller ! [    5.003431] pcieport 0000:00:00.0: PME: Signaling with IRQ 88 [    5.004457] pcieport 0000:00:00.0: AER: enabled with IRQ 97 [    5.023022] printk: console [netcon0] enabled [    5.023454] netconsole: network logging started [    5.025025] ALSA device list: [    5.025325]  No soundcards found. [    5.025960] dw-apb-uart fe660000.serial: forbid DMA for kernel console [    5.041707] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [    5.042703] VFS: Mounted root (ext4 filesystem) readonly on device 179:3. [    5.044346] devtmpfs: mounted [    5.046057] Freeing unused kernel memory: 3008K [    5.079833] Run /sbin/init as init process INIT: version 2.99 booting mount: proc mounted on /proc. mount: sysfs mounted on /sys. mount: tmpfs mounted on /run. Creating static nodes in /dev. Starting udevd:  /sbin/udevd --daemon [    6.354551] random: udevd: uninitialized urandom read (16 bytes read) [    6.356748] random: udevd: uninitialized urandom read (16 bytes read) [    6.357413] random: udevd: uninitialized urandom read (16 bytes read) Triggering udev events:  /sbin/udevadm trigger --action=add [    6.438215] udevd[470]: starting eudev-3.2.10 [    6.783001] rk808-rtc rk808-rtc: registered as rtc0 [    6.786364] rk808-rtc rk808-rtc: setting system clock to 2017-08-05T14:38:30 UTC (1501943910) [    6.842339] optee: probing for conduit method. [    6.842812] optee: revision 3.6 (0b06ae94) [    6.848660] optee: initialized driver [    6.862781] mmc1: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA Setting the system clock rate:  /sbin/adjtimex --tick 10000 --frequency 0 Setting system time from the hardware clock (localtime):  Sat Aug  5 14:38:31 UTC 2017 Testing root filesystem status:  read-only filesystem Checking root filesystem: fsck from util-linux 2.37 /dev/mmcblk0p3: clean, 164877/1941504 files, 1203295/7752443 blocks Remounting root device with read-write enabled. [    7.656763] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null). Quota mode: none. mount: /dev/mmcblk0p3 mounted on /. Updating module dependency list for 5.13.0-rc4-next-20210603:  /sbin/depmod --quick Configuring kernel parameters:  /sbin/sysctl -e --system * Applying /etc/sysctl.d/10-ext4_tune.conf ... vm.dirty_writeback_centisecs = 100 vm.dirty_expire_centisecs = 100 * Applying /etc/sysctl.d/swap.conf ... vm.swappiness = 10 Checking non-root filesystems: fsck from util-linux 2.37 Mounting non-root local filesystems: tmpfs on /dev/shm type tmpfs (rw) shm on /dev/shm type tmpfs (rw) [    8.211689] Adding 131068k swap on /swap.  Priority:5 extents:10 across:237564k SSFS Using /etc/random-seed to initialize /dev/urandom. [    8.331695] urandom_read: 5 callbacks suppressed [    8.331721] random: dd: uninitialized urandom read (512 bytes read) INIT: Entering runlevel: 3 Going multiuser... Updating shared library links:  /sbin/ldconfig & setterm: cannot (un)set powersave mode: Inappropriate ioctl for device Starting syslogd daemon:  /usr/sbin/syslogd -s Updating hardware database index:  /sbin/udevadm hwdb --update Triggering udev events:  /sbin/udevadm trigger --action=change Starting the network interfaces... eth0: polling for DHCP server eth0: waiting for carrier eth0: carrier acquired DUID 00:01:00:01:21:18:84:8d:ea:3f:7c:5f:8a:a0 eth0: IAID 7c:5f:8a:a0 eth0: carrier lost timed out dhcpcd exited Starting system message bus:  /usr/bin/dbus-uuidgen --ensure ; /usr/bin/dbus-daemon --system Starting elogind:  /lib64/elogind/elogind --daemon Starting OpenSSH SSH daemon:  /usr/sbin/sshd devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620) Starting NTP daemon:  /usr/sbin/ntpd -g -u ntp:ntp Compiling GSettings XML schema files:   /usr/bin/glib-compile-schemas /usr/share/glib-2.0/schemas & Starting crond:  /usr/sbin/crond -l notice Loading /usr/share/kbd/keymaps/i386/qwerty/us.map.gz Running script /etc/rc.d/rc.local: ======================================================================= if you want to transfer the system to SDcard to internal memory (eMMC or NAND), follow transfer-to-disk ======================================================================= slarm64 GNU/Linux (ttyS2) Kernel 5.13.0-rc4-next-20210603 (aarch64) quartz64 login:
donation   irradium
kernel 5.13.0
slarm64-current-aarch64-server-quartz64-5.13.0-build-20210718.img.zst
slarm64-current-aarch64-server-quartz64-5.13.0-build-20210718.img.zst.sha256
donation   irradium
(07-18-2021, 12:59 AM)mara Wrote: kernel 5.13.0
Thanks on porting Slackware to Quartz64 SBC :-)
kernel 5.14.0
slarm64-current-aarch64-server-quartz64-5.14.0-rc1-build-20210820.img.zst
slarm64-current-aarch64-server-quartz64-5.14.0-rc1-build-20210820.img.zst.sha256
donation   irradium
kernel 4.19.209
Working
  • LAN
  • USB2
  • HDMI
slarm64-current-aarch64-server-quartz64-4.19.209-build-20211008.img.zst
slarm64-current-aarch64-server-quartz64-4.19.209-build-20211008.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-4.19.209-build-20211008.img.zst
slarm64-current-aarch64-xfce-quartz64-4.19.209-build-20211008.img.zst.sha256
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux version 4.19.209 (root@slarm64-dev) (gcc version 11.2.0 (GCC), GNU ld version 2.37-slack15) #1 SMP Fri Oct 8 22:30:38 UTC 2021 [    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board [    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '') [    0.000000] bootconsole [uart8250] enabled [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [    0.000000] cma: Reserved 16 MiB at 0x00000000ef000000 [    0.000000] On node 0 totalpages: 2031104 [    0.000000]   DMA32 zone: 15352 pages used for memmap [    0.000000]   DMA32 zone: 0 pages reserved [    0.000000]   DMA32 zone: 982528 pages, LIFO batch:63 [    0.000000]   Normal zone: 16384 pages used for memmap [    0.000000]   Normal zone: 1048576 pages, LIFO batch:63 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.1 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: MIGRATE_INFO_TYPE not supported. [    0.000000] psci: SMC Calling Convention v1.2 [    0.000000] percpu: Embedded 23 pages/cpu s54376 r8192 d31640 u94208 [    0.000000] pcpu-alloc: s54376 r8192 d31640 u94208 alloc=23*4096 [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: Virtualization Host Extensions [    0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1999368 [    0.000000] Kernel command line: root=/dev/mmcblk0p3 ro rootwait rootfstype=ext4 init=/sbin/init loglevel=4 earlycon=uart8250,mmio32,0xfe660000 console=tty1 console=ttyFIQ0,1500000n8 [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes) [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes) [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [    0.000000] software IO TLB: mapped [mem 0xeafff000-0xeefff000] (64MB) [    0.000000] Memory: 7872728K/8124416K available (13886K kernel code, 2028K rwdata, 4876K rodata, 1600K init, 1799K bss, 235304K reserved, 16384K cma-reserved) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] ftrace: allocating 51020 entries in 200 pages [    0.000000] rcu: Hierarchical RCU implementation. [    0.000000] rcu:     RCU event tracing is enabled. [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] GICv3: no VLPI support, no direct LPI support [    0.000000] ITS [mem 0xfd440000-0xfd45ffff] [    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0) [    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0) [    0.000000] ITS: using cache flushing for cmd queue [    0.000000] GIC: using LPI property table @0x0000000000230000 [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    0.000000] CPU0: using LPI pending table @0x0000000000240000 [    0.000000] GIC: using cache flushing for LPI property table [    0.000000] random: random: get_random_bytes called from start_kernel+0x358/0x4e0 with crng_init=0 [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001358] Console: colour dummy device 80x25 [    0.001376] console [tty1] enabled [    0.001420] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [    0.001432] pid_max: default: 32768 minimum: 301 [    0.001647] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) [    0.001691] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) [    0.003578] ASID allocator initialised with 32768 entries [    0.003744] rcu: Hierarchical SRCU implementation. [    0.006699] Platform MSI: interrupt-controller@fd440000 domain created [    0.007190] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created [    0.007940] smp: Bringing up secondary CPUs ... [    0.008742] Detected VIPT I-cache on CPU1 [    0.008782] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    0.008838] CPU1: using LPI pending table @0x0000000000250000 [    0.008901] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    0.009905] Detected VIPT I-cache on CPU2 [    0.009939] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    0.009990] CPU2: using LPI pending table @0x0000000000260000 [    0.010036] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    0.010889] Detected VIPT I-cache on CPU3 [    0.010919] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [    0.010972] CPU3: using LPI pending table @0x0000000000270000 [    0.011017] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [    0.011154] smp: Brought up 1 node, 4 CPUs [    0.011162] SMP: Total of 4 processors activated. [    0.011169] CPU features: detected: GIC system register CPU interface [    0.011173] CPU features: detected: Privileged Access Never [    0.011176] CPU features: detected: LSE atomic instructions [    0.011181] CPU features: detected: User Access Override [    0.011185] CPU features: detected: 32-bit EL0 Support [    0.011189] CPU features: detected: RAS Extension Support [    0.011361] CPU: All CPU(s) started at EL2 [    0.011393] alternatives: patching kernel code [    0.020057] devtmpfs: initialized [    0.044801] Registered cp15_barrier emulation handler [    0.044817] Registered setend emulation handler [    0.045168] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [    0.045188] futex hash table entries: 1024 (order: 4, 65536 bytes) [    0.046051] pinctrl core: initialized pinctrl subsystem [    0.046396] regulator-dummy: no parameters [    0.047172] NET: Registered protocol family 16 [    0.051480] cpuidle: using governor menu [    0.051516] Registered FIQ tty driver [    0.052068] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.053871] DMA: preallocated 2048 KiB pool for atomic allocations [    0.057664] console [pstore-1] enabled [    0.057670] pstore: Registered ramoops as persistent store backend [    0.057677] ramoops: attached 0xf0000@0x110000, ecc: 0/0 [    0.093813] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio) [    0.094560] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio) [    0.095251] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio) [    0.095968] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio) [    0.096660] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio) [    0.096774] rockchip-pinctrl pinctrl: probed pinctrl [    0.112098] cryptd: max_cpu_qlen set to 1000 [    0.114018] console [ttyFIQ0] enabled [    0.114024] bootconsole [uart8250] disabled [    0.114313] Registered fiq debugger ttyFIQ0 [    0.114951] vcc5v0_host: 5000 mV [    0.115208] reg-fixed-voltage vcc5v0_host: vcc5v0_host supplying 5000000uV [    0.115343] vcc3v8_sys: 3800 mV [    0.115593] reg-fixed-voltage vccsys: vcc3v8_sys supplying 3800000uV [    0.115882] vcc_camera: no parameters [    0.116111] reg-fixed-voltage vcc-camera-regulator: vcc_camera supplying 0uV [    0.116359] vcc3v3_pcie_p: 3300 mV [    0.116538] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.116553] vcc3v3_pcie_p: regulator get failed, ret=-517 [    0.116641] fbcon: Taking over console [    0.116660] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.116673] vcc3v3_pcie_p: unable to resolve supply [    0.116684] reg-fixed-voltage vcc3v3_pcie_p: vcc3v3_pcie_p supplying 3300000uV [    0.117460] vcc_sd: 3300 mV [    0.117771] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.117787] vcc3v3_pcie_p: unable to resolve supply [    0.118364] rk_iommu fdea0800.iommu: version = 2 [    0.118826] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply from device tree [    0.118853] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply property in node /power-management@fdd90000/power-controller failed [    0.119046] rk_iommu fded0480.iommu: version = 2 [    0.119301] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply from device tree [    0.119325] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@fdd90000/power-controller failed [    0.119574] rk_iommu fdee0800.iommu: version = 2 [    0.120005] rk_iommu fdf40f00.iommu: version = 2 [    0.120310] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply from device tree [    0.120334] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply property in node /power-management@fdd90000/power-controller failed [    0.120517] rk_iommu fdf80800.iommu: version = 2 [    0.120789] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply from device tree [    0.120814] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply property in node /power-management@fdd90000/power-controller failed [    0.121025] rk_iommu fdff1a00.iommu: version = 2 [    0.121279] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree [    0.121304] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed [    0.121466] rk_iommu fe043e00.iommu: version = 2 [    0.122453] SCSI subsystem initialized [    0.122511] libata version 3.00 loaded. [    0.122760] usbcore: registered new interface driver usbfs [    0.122820] usbcore: registered new interface driver hub [    0.122881] usbcore: registered new device driver usb [    0.122986] media: Linux media interface: v0.10 [    0.123032] videodev: Linux video capture interface: v2.00 [    0.123120] pps_core: LinuxPPS API ver. 1 registered [    0.123126] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    0.123146] PTP clock support registered [    0.123530] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [    0.126272] Advanced Linux Sound Architecture Driver Initialized. [    0.126865] Bluetooth: Core ver 2.22 [    0.126932] NET: Registered protocol family 31 [    0.126937] Bluetooth: HCI device and connection manager initialized [    0.126951] Bluetooth: HCI socket layer initialized [    0.126958] Bluetooth: L2CAP socket layer initialized [    0.126996] Bluetooth: SCO socket layer initialized [    0.127579] rockchip-cpuinfo cpuinfo: SoC            : 35661000 [    0.127589] rockchip-cpuinfo cpuinfo: Serial         : a9bbfa768e1e4946 [    0.128728] clocksource: Switched to clocksource arch_sys_counter [    0.231898] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [    0.232355] NET: Registered protocol family 2 [    0.232804] IP idents hash table entries: 131072 (order: 8, 1048576 bytes) [    0.237002] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes) [    0.237180] TCP established hash table entries: 65536 (order: 7, 524288 bytes) [    0.237707] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes) [    0.239767] TCP: Hash tables configured (established 65536 bind 65536) [    0.239940] UDP hash table entries: 4096 (order: 6, 393216 bytes) [    0.240336] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes) [    0.240923] NET: Registered protocol family 1 [    0.241602] RPC: Registered named UNIX socket transport module. [    0.241608] RPC: Registered udp transport module. [    0.241612] RPC: Registered tcp transport module. [    0.241615] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.242486] PCI: CLS 0 bytes, default 64 [    0.244675] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [    0.247284] Initialise system trusted keyrings [    0.247515] workingset: timestamp_bits=61 max_order=21 bucket_order=0 [    0.256248] squashfs: version 4.0 (2009/01/31) Phillip Lougher [    0.257506] NFS: Registering the id_resolver key type [    0.257535] Key type id_resolver registered [    0.257540] Key type id_legacy registered [    0.257559] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [    0.257565] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [    0.257570] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [    0.258424] ntfs: driver 2.1.32 [Flags: R/O]. [    0.258692] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc. [    0.259297] fuse init (API version 7.27) [    0.259721] SGI XFS with security attributes, no debug enabled [    0.263233] NET: Registered protocol family 38 [    0.263259] Key type asymmetric registered [    0.263265] Asymmetric key parser 'x509' registered [    0.263317] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [    0.263325] io scheduler noop registered [    0.263330] io scheduler deadline registered [    0.263491] io scheduler cfq registered (default) [    0.263498] io scheduler mq-deadline registered [    0.263503] io scheduler kyber registered [    0.264745] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully! [    0.264912] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully! [    0.267406] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree [    0.267430] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0 err -2 [    0.267488] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.1 [    0.267630] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree [    0.267649] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.1 err -2 [    0.267699] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.1 [    0.267808] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree [    0.267822] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed [    0.267840] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port [    0.269574] extcon extcon1: failed to create extcon usb2-phy link [    0.269689] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree [    0.269718] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.2 err -2 [    0.269800] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.1 [    0.269942] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree [    0.269961] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.3 err -2 [    0.270013] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.1 [    0.270121] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree [    0.270135] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed [    0.270153] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port [    0.272538] phy phy-fe850000.video-phy.4: Looking up phy-supply from device tree [    0.272554] phy phy-fe850000.video-phy.4: Looking up phy-supply property in node /video-phy@fe850000 failed [    0.278664] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree [    0.278694] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.279293] pwm-backlight backlight: Looking up power-supply from device tree [    0.279308] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [    0.279326] pwm-backlight backlight: backlight supply power not found, using dummy regulator [    0.279418] pwm-backlight backlight: Linked as a consumer to regulator.0 [    0.279747] mpp_service mpp-srv: 7cf7399dd author: Stephen 2021-08-23 arm64: dts: rk3568-rock3a: enable pwm8 for fan [    0.279754] mpp_service mpp-srv: probe start [    0.280952] iommu: Adding device fdf40000.rkvenc to group 3 [    0.280981] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu [    0.281243] mpp_rkvenc fdf40000.rkvenc: probing start [    0.281840] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree [    0.281856] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply property in node /rkvenc@fdf40000 failed [    0.281875] mpp_rkvenc fdf40000.rkvenc: no regulator, devfreq is disabled [    0.282360] mpp_rkvenc fdf40000.rkvenc: probing finish [    0.283723] iommu: Adding device fdea0400.vdpu to group 0 [    0.283753] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu [    0.283976] mpp_vdpu2 fdea0400.vdpu: probe device [    0.284756] mpp_vdpu2 fdea0400.vdpu: probing finish [    0.285459] iommu: Adding device fdee0000.vepu to group 2 [    0.285488] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu [    0.285732] mpp_vepu2 fdee0000.vepu: probe device [    0.286507] mpp_vepu2 fdee0000.vepu: probing finish [    0.287501] iommu: Adding device fded0000.jpegd to group 1 [    0.287529] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu [    0.287714] mpp_jpgdec fded0000.jpegd: probe device [    0.288499] mpp_jpgdec fded0000.jpegd: probing finish [    0.289190] iommu: Adding device fdf80200.rkvdec to group 4 [    0.289219] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu [    0.289526] mpp_rkvdec2 fdf80200.rkvdec: probing start [    0.290181] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found! [    0.290241] rkvdec2_init:875: No niu aclk reset resource define [    0.290273] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found! [    0.290299] rkvdec2_init:878: No niu hclk reset resource define [    0.290775] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000 [    0.290784] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000 [    0.290791] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056 [    0.290798] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536 [    0.290807] mpp_rkvdec2 fdf80200.rkvdec: min_width 512 [    0.290839] mpp_rkvdec2 fdf80200.rkvdec: probing finish [    0.291252] mpp_service mpp-srv: probe success [    0.299170] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [    0.299184] dma-pl330 fe530000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    0.302485] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [    0.302497] dma-pl330 fe550000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    0.304863] rockchip-system-monitor rockchip-system-monitor: system monitor probe [    0.306083] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [    0.306907] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 17, base_baud = 1500000) is a 16550A [    0.307811] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 62, base_baud = 1500000) is a 16550A [    0.311010] random: fast init done [    0.311335] random: crng init done [    0.312227] iommu: Adding device fe040000.vop to group 6 [    0.312267] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu [    0.318848] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop [    0.320204] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi [    0.320729] rockchip-drm display-subsystem: Linked as a consumer to fe060000.dsi [    0.322392] rockchip-drm display-subsystem: defer getting devfreq [    0.322736] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x0, primary plane phy id: -1 [    0.322753] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1 [    0.322767] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1 [    0.323110] [drm] unsupported AFBC format[3432564e] [    0.323172] [drm] failed to init overlay plane Cluster0-win1 [    0.323243] [drm] failed to init overlay plane Cluster1-win1 [    0.323533] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008ef7890) [    0.323786] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [    0.324562] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [    0.325457] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008efb8b0) [    0.325514] dw-mipi-dsi fe060000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517 [    0.333229] panel-simple-dsi fe060000.dsi.0: Looking up power-supply from device tree [    0.333256] panel-simple-dsi fe060000.dsi.0: Looking up power-supply property in node /dsi@fe060000/panel@0 failed [    0.333276] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply power not found, using dummy regulator [    0.333365] panel-simple-dsi fe060000.dsi.0: Linked as a consumer to regulator.0 [    0.333378] panel-simple-dsi fe060000.dsi.0: Looking up vsp-supply from device tree [    0.333399] panel-simple-dsi fe060000.dsi.0: Looking up vsp-supply property in node /dsi@fe060000/panel@0 failed [    0.333412] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply vsp not found, using dummy regulator [    0.333498] panel-simple-dsi fe060000.dsi.0: Looking up vsn-supply from device tree [    0.333519] panel-simple-dsi fe060000.dsi.0: Looking up vsn-supply property in node /dsi@fe060000/panel@0 failed [    0.333532] panel-simple-dsi fe060000.dsi.0: fe060000.dsi.0 supply vsn not found, using dummy regulator [    0.334832] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply from device tree [    0.334857] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@fdd90000/power-controller failed [    0.334913] mali fde60000.gpu: Kernel DDK version g2p0-01eac0 [    0.335005] mali fde60000.gpu: Looking up mali-supply from device tree [    0.335028] mali fde60000.gpu: Power management initialization failed error = -517 [    0.335111] mali fde60000.gpu: Device initialization Deferred [    0.335668] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    0.336626] brd: module loaded [    0.345941] loop: module loaded [    0.346526] zram: Added device: zram0 [    0.346680] lkdtm: No crash points registered, enable through debugfs [    0.350516] libphy: Fixed MDIO Bus: probed [    0.352030] clk: failed to reparent clk_gmac1_rx_tx to gmac1_clkin: -22 [    0.352636] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree [    0.352661] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed [    0.352683] rk_gmac-dwmac fe010000.ethernet: no regulator found [    0.352734] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [    0.352743] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f). [    0.352752] rk_gmac-dwmac fe010000.ethernet: RX delay(0x25). [    0.352765] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [    0.352827] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [    0.357846] rk_gmac-dwmac fe010000.ethernet: init for RGMII [    0.358172] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [    0.358185] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5 [    0.358194] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [    0.358201] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [    0.358207] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [    0.358212] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [    0.358261] rk_gmac-dwmac fe010000.ethernet: TSO supported [    0.358269] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [    0.358277] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [    0.488765] libphy: stmmac: probed [    0.491884] usbcore: registered new interface driver rndis_wlan [    0.491951] usbcore: registered new interface driver rtl8150 [    0.492013] usbcore: registered new interface driver r8152 [    0.492130] usbcore: registered new interface driver asix [    0.492188] usbcore: registered new interface driver ax88179_178a [    0.492237] usbcore: registered new interface driver cdc_ether [    0.492298] usbcore: registered new interface driver rndis_host [    0.492365] usbcore: registered new interface driver cdc_ncm [    0.492414] usbcore: registered new interface driver cdc_mbim [    0.493982] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2 [    0.503208] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    0.503230] ehci-pci: EHCI PCI platform driver [    0.503327] ehci-platform: EHCI generic platform driver [    0.505484] ehci-platform fd800000.usb: EHCI Host Controller [    0.505751] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [    0.506411] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000 [    0.518751] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [    0.519101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [    0.519112] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.519119] usb usb1: Product: EHCI Host Controller [    0.519126] usb usb1: Manufacturer: Linux 4.19.209 ehci_hcd [    0.519132] usb usb1: SerialNumber: fd800000.usb [    0.519821] hub 1-0:1.0: USB hub found [    0.519875] hub 1-0:1.0: 1 port detected [    0.522676] ehci-platform fd880000.usb: EHCI Host Controller [    0.522920] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [    0.523557] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000 [    0.535433] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [    0.535724] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [    0.535735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.535743] usb usb2: Product: EHCI Host Controller [    0.535750] usb usb2: Manufacturer: Linux 4.19.209 ehci_hcd [    0.535756] usb usb2: SerialNumber: fd880000.usb [    0.536372] hub 2-0:1.0: USB hub found [    0.536424] hub 2-0:1.0: 1 port detected [    0.537399] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    0.537422] ohci-platform: OHCI generic platform driver [    0.537742] ohci-platform fd840000.usb: Generic Platform OHCI controller [    0.538000] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [    0.538329] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000 [    0.596353] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [    0.596364] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.596372] usb usb3: Product: Generic Platform OHCI controller [    0.596379] usb usb3: Manufacturer: Linux 4.19.209 ohci_hcd [    0.596385] usb usb3: SerialNumber: fd840000.usb [    0.597013] hub 3-0:1.0: USB hub found [    0.597067] hub 3-0:1.0: 1 port detected [    0.597791] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [    0.598030] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [    0.598390] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000 [    0.656360] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [    0.656370] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    0.656378] usb usb4: Product: Generic Platform OHCI controller [    0.656385] usb usb4: Manufacturer: Linux 4.19.209 ohci_hcd [    0.656392] usb usb4: SerialNumber: fd8c0000.usb [    0.657013] hub 4-0:1.0: USB hub found [    0.657066] hub 4-0:1.0: 1 port detected [    0.659108] usbcore: registered new interface driver cdc_acm [    0.659113] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [    0.659186] usbcore: registered new interface driver cdc_wdm [    0.659500] usbcore: registered new interface driver uas [    0.659665] usbcore: registered new interface driver usb-storage [    0.659804] usbcore: registered new interface driver usbserial_generic [    0.659838] usbserial: USB Serial support registered for generic [    0.659899] usbcore: registered new interface driver cp210x [    0.659927] usbserial: USB Serial support registered for cp210x [    0.660027] usbcore: registered new interface driver ftdi_sio [    0.660063] usbserial: USB Serial support registered for FTDI USB Serial Device [    0.660301] usbcore: registered new interface driver keyspan [    0.660332] usbserial: USB Serial support registered for Keyspan - (without firmware) [    0.660359] usbserial: USB Serial support registered for Keyspan 1 port adapter [    0.660388] usbserial: USB Serial support registered for Keyspan 2 port adapter [    0.660414] usbserial: USB Serial support registered for Keyspan 4 port adapter [    0.660480] usbcore: registered new interface driver option [    0.660509] usbserial: USB Serial support registered for GSM modem (1-port) [    0.660845] usbcore: registered new interface driver oti6858 [    0.660883] usbserial: USB Serial support registered for oti6858 [    0.660944] usbcore: registered new interface driver pl2303 [    0.660980] usbserial: USB Serial support registered for pl2303 [    0.661054] usbcore: registered new interface driver qcserial [    0.661085] usbserial: USB Serial support registered for Qualcomm USB modem [    0.661174] usbcore: registered new interface driver sierra [    0.661205] usbserial: USB Serial support registered for Sierra USB modem [    0.663196] usbcore: registered new interface driver usbtouchscreen [    0.663266] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0 [    0.663274] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0 [    0.664278] i2c /dev entries driver [    0.666693] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [    0.667206] vdd_cpu: override max_uV, 1390000 -> 1387500 [    0.669482] vdd_cpu: 712 <--> 1387 mV at 1025 mV [    0.670193] fan53555-regulator 0-001c: Looking up vin-supply from device tree [    0.670209] vdd_cpu: supplied by vcc3v8_sys [    0.670868] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.670886] vcc3v3_pcie_p: unable to resolve supply [    0.672405] rk808 0-0020: chip id: 0x8170 [    0.672461] rk808 0-0020: No cache defaults, reading back from HW [    0.696247] rk808 0-0020: source: on=0x40, off=0x00 [    0.696263] rk808 0-0020: support dcdc3 fb mode:-22, 63 [    0.696273] rk808 0-0020: support pmic reset mode:0,0 [    0.705029] rk808-regulator rk808-regulator: there is no dvs0 gpio [    0.705059] rk808-regulator rk808-regulator: there is no dvs1 gpio [    0.705537] vdd_logic: 500 <--> 1350 mV at 900 mV [    0.705790] rk808 0-0020: Looking up vcc1-supply from device tree [    0.705807] vdd_logic: supplied by vcc3v8_sys [    0.705971] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.705989] vcc3v3_pcie_p: unable to resolve supply [    0.706428] vdd_gpu: 500 <--> 1350 mV at 900 mV [    0.706646] rk808 0-0020: Looking up vcc2-supply from device tree [    0.706661] vdd_gpu: supplied by vcc3v8_sys [    0.706820] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.706838] vcc3v3_pcie_p: unable to resolve supply [    0.706900] vcc_ddr: at 500 mV [    0.707109] rk808 0-0020: Looking up vcc3-supply from device tree [    0.707124] vcc_ddr: supplied by vcc3v8_sys [    0.707278] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.707295] vcc3v3_pcie_p: unable to resolve supply [    0.707372] vcc_3v3: 3300 mV [    0.707576] rk808 0-0020: Looking up vcc4-supply from device tree [    0.707590] vcc_3v3: supplied by vcc3v8_sys [    0.707741] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.707759] vcc3v3_pcie_p: unable to resolve supply [    0.707834] vcca1v8_pmu: 1800 mV [    0.708025] rk808 0-0020: Looking up vcc5-supply from device tree [    0.708038] vcca1v8_pmu: supplied by vcc3v8_sys [    0.708181] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.708199] vcc3v3_pcie_p: unable to resolve supply [    0.708636] vdda_0v9: 900 mV [    0.708887] rk808 0-0020: Looking up vcc5-supply from device tree [    0.708901] vdda_0v9: supplied by vcc3v8_sys [    0.709024] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.709041] vcc3v3_pcie_p: unable to resolve supply [    0.709120] vdda0v9_pmu: 900 mV [    0.709333] rk808 0-0020: Looking up vcc5-supply from device tree [    0.709347] vdda0v9_pmu: supplied by vcc3v8_sys [    0.709470] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.709488] vcc3v3_pcie_p: unable to resolve supply [    0.709557] vccio_acodec: Bringing 1800000uV into 3300000-3300000uV [    0.709934] vccio_acodec: ramp_delay not set [    0.710839] vccio_acodec: 3300 mV [    0.711055] rk808 0-0020: Looking up vcc6-supply from device tree [    0.711069] vccio_acodec: supplied by vcc3v8_sys [    0.711191] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.711208] vcc3v3_pcie_p: unable to resolve supply [    0.711652] vccio_sd: 1800 <--> 3300 mV at 3300 mV [    0.711849] rk808 0-0020: Looking up vcc6-supply from device tree [    0.711863] vccio_sd: supplied by vcc3v8_sys [    0.712001] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.712018] vcc3v3_pcie_p: unable to resolve supply [    0.712500] vcc3v3_pmu: 3300 mV [    0.712703] rk808 0-0020: Looking up vcc6-supply from device tree [    0.712717] vcc3v3_pmu: supplied by vcc3v8_sys [    0.712856] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.712873] vcc3v3_pcie_p: unable to resolve supply [    0.713320] vcc_1v8: 1800 mV [    0.713523] rk808 0-0020: Looking up vcc7-supply from device tree [    0.713537] vcc_1v8: supplied by vcc3v8_sys [    0.713672] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.713689] vcc3v3_pcie_p: unable to resolve supply [    0.714662] vcc1v8_dvp: 1800 mV [    0.714872] rk808 0-0020: Looking up vcc7-supply from device tree [    0.714886] vcc1v8_dvp: supplied by vcc3v8_sys [    0.715021] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.715038] vcc3v3_pcie_p: unable to resolve supply [    0.715117] vcc2v8_dvp: Bringing 1800000uV into 2800000-2800000uV [    0.715492] vcc2v8_dvp: ramp_delay not set [    0.716394] vcc2v8_dvp: 2800 mV [    0.716601] rk808 0-0020: Looking up vcc7-supply from device tree [    0.716615] vcc2v8_dvp: supplied by vcc3v8_sys [    0.716732] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.716748] vcc3v3_pcie_p: unable to resolve supply [    0.716828] boost: Bringing 4700000uV into 5000000-5000000uV [    0.717193] boost: ramp_delay not set [    0.718089] boost: 5000 mV [    0.718303] rk808 0-0020: Looking up vcc8-supply from device tree [    0.718317] boost: supplied by vcc3v8_sys [    0.718438] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.718455] vcc3v3_pcie_p: unable to resolve supply [    0.718530] otg_switch: no parameters [    0.718760] rk808 0-0020: Looking up vcc9-supply from device tree [    0.718784] otg_switch: supplied by boost [    0.718907] reg-fixed-voltage vcc3v3_pcie_p: Looking up vin-supply from device tree [    0.718925] vcc3v3_pcie_p: unable to resolve supply [    0.719210] rk817-battery rk817-battery: DMA mask not set [    0.719389] rk817-battery rk817-battery: fb_temperature missing! [    0.719455] rk817-battery rk817-battery: energy_mode missing! [    0.719485] rk817-battery rk817-battery: zero_reserve_dsoc missing! [    0.720015] rk817-battery rk817-battery: low_power_sleep missing! [    0.791256] thermal thermal_zone2: power_allocator: sustainable_power will be estimated [    0.791644] rk817-charger rk817-charger: DMA mask not set [    0.791733] rk817-charger rk817-charger: power_dc2otg missing! [    0.791785] rk817-charger rk817-charger: sample_res missing! [    0.791814] rk817-charger rk817-charger: otg5v_suspend_enable missing! [    0.791839] rk817-charger rk817-charger: gate_function_disable missing! [    0.792368] rk817-charger rk817-charger: Looking up otg_switch-supply from device tree [    0.792382] rk817-charger rk817-charger: Looking up otg_switch-supply property in node /i2c@fdd40000/pmic@20/charger failed [    0.792488] rk817-charger rk817-charger: Linked as a consumer to regulator.21 [    0.804660] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0 [    0.811449] rk808-rtc rk808-rtc: registered as rtc0 [    0.813212] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:04 UTC (1501837204) [    0.815877] rockchip-pinctrl pinctrl: pin gpio3-13 already requested by fe010000.ethernet; cannot claim for fe5c0000.i2c [    0.815954] rockchip-pinctrl pinctrl: pin-109 (fe5c0000.i2c) status -22 [    0.815985] rockchip-pinctrl pinctrl: could not request pin 109 (gpio3-13) from group i2c3m1-xfer  on device rockchip-pinctrl [    0.816039] rk3x-i2c fe5c0000.i2c: Error applying setting, reverse things back [    0.816099] rk3x-i2c: probe of fe5c0000.i2c failed with error -22 [    0.816213] rockchip-pinctrl pinctrl: pin gpio3-11 already requested by fe010000.ethernet; cannot claim for fe5e0000.i2c [    0.816258] rockchip-pinctrl pinctrl: pin-107 (fe5e0000.i2c) status -22 [    0.816304] rockchip-pinctrl pinctrl: could not request pin 107 (gpio3-11) from group i2c5m0-xfer  on device rockchip-pinctrl [    0.816353] rk3x-i2c fe5e0000.i2c: Error applying setting, reverse things back [    0.816406] rk3x-i2c: probe of fe5e0000.i2c failed with error -22 [    0.818889] iommu: Adding device fdff0000.rkisp to group 5 [    0.818923] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu [    0.819189] rkisp_hw fdff0000.rkisp: is_thunderboot: 0 [    0.819200] rkisp_hw fdff0000.rkisp: max input:0x0@0fps [    0.819231] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff] [    0.820384] rkisp rkisp-vir0: rkisp driver version: v01.06.01 [    0.820494] rkisp rkisp-vir0: No memory-region-thunderboot specified [    0.820754] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized! [    0.820773] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized! [    0.823472] usbcore: registered new interface driver uvcvideo [    0.823477] USB Video Class driver (1.1.1) [    0.823835] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree [    0.823952] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.16 [    0.823989] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu [    0.824018] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree [    0.824117] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.10 [    0.824152] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc_3v3 [    0.824182] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree [    0.824261] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.14 [    0.824293] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec [    0.824330] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree [    0.824409] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.17 [    0.824440] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8 [    0.824467] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree [    0.824566] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.15 [    0.824600] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd [    0.824630] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree [    0.824710] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.11 [    0.824742] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcca1v8_pmu [    0.824770] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree [    0.824860] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3 [    0.824887] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree [    0.824989] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.18 [    0.825024] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc1v8_dvp [    0.825054] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree [    0.825145] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3 [    0.829775] rockchip-thermal fe710000.tsadc: tsadc is probed successfully! [    0.831245] Bluetooth: HCI UART driver ver 2.3 [    0.831253] Bluetooth: HCI UART protocol H4 registered [    0.831258] Bluetooth: HCI UART protocol ATH3K registered [    0.831361] usbcore: registered new interface driver bfusb [    0.831437] usbcore: registered new interface driver btusb [    0.831856] cpu cpu0: leakage=26 [    0.831923] cpu cpu0: Looking up cpu-supply from device tree [    0.832518] cpu cpu0: Linked as a consumer to regulator.6 [    0.859545] cpu cpu0: temp=33750, pvtm=88534 (88716 + -182) [    0.862637] cpu cpu0: Dropping the link to regulator.6 [    0.862687] cpu cpu0: pvtm-volt-sel=1 [    0.863054] cpu cpu0: Looking up cpu-supply from device tree [    0.863634] cpu cpu0: Linked as a consumer to regulator.6 [    0.863691] cpu cpu0: Dropping the link to regulator.6 [    0.863823] cpu cpu0: Looking up cpu-supply from device tree [    0.864364] cpu cpu0: Linked as a consumer to regulator.6 [    0.865350] cpu cpu0: avs=0 [    0.865499] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1 [    0.865751] energy_model: Created perf domain 0-3 [    0.865804] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [    0.870618] rockchip-pinctrl pinctrl: pin gpio0-16 already requested by fdd50000.serial; cannot claim for sdio-pwrseq [    0.870702] rockchip-pinctrl pinctrl: pin-16 (sdio-pwrseq) status -22 [    0.870735] rockchip-pinctrl pinctrl: could not request pin 16 (gpio0-16) from group wifi-enable-h  on device rockchip-pinctrl [    0.870786] pwrseq_simple sdio-pwrseq: Error applying setting, reverse things back [    0.870845] pwrseq_simple: probe of sdio-pwrseq failed with error -22 [    0.871426] sdhci: Secure Digital Host Controller Interface driver [    0.871430] sdhci: Copyright(c) Pierre Ossman [    0.871434] Synopsys Designware Multimedia Card Interface Driver [    0.872678] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode. [    0.872970] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller. [    0.872982] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a [    0.873038] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 48,32 bit host data width,256 deep fifo [    0.873063] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree [    0.873188] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.5 [    0.873197] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree [    0.873269] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.15 [    0.886519] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    0.899833] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    0.900023] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    0.900034] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    0.900097] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    0.900121] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    0.900133] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    0.900167] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    0.900175] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    0.900589] sdhci-pltfm: SDHCI platform and OF driver helper [    0.901744] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree [    0.901756] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed [    0.901785] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree [    0.901792] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed [    0.901813] mmc2: Unknown controller version (5). You may experience problems. [    0.925757] vccio_sd: ramp_delay not set [    0.934165] mmc2: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA [    0.935321] ledtrig-cpu: registered to indicate activity on CPUs [    0.935959] hidraw: raw HID events driver (C) Jiri Kosina [    0.936352] usbcore: registered new interface driver usbhid [    0.936355] usbhid: USB HID core driver [    0.936643] rockchip,bus bus-npu: Looking up bus-supply from device tree [    0.936712] rockchip,bus bus-npu: Linked as a consumer to regulator.7 [    0.936726] rockchip,bus bus-npu: Failed to get leakage [    0.936822] rockchip,bus bus-npu: pvtm = 88534, form pvtm_value [    0.936832] rockchip,bus bus-npu: pvtm-volt-sel=1 [    0.937027] rockchip,bus bus-npu: avs=0 [    0.939602] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree [    0.939674] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.17 [    0.940334] optee: probing for conduit method from DT. [    0.940339] optee: api uid mismatch [    0.940343] rksfc_base v1.1 2016-01-08 [    0.941298] usbcore: registered new interface driver snd-usb-audio [    0.943113] rk817-codec rk817-codec: DMA mask not set [    0.948390] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [    0.949853] Initializing XFRM netlink socket [    0.950686] NET: Registered protocol family 10 [    0.952246] Segment Routing with IPv6 [    0.952344] NET: Registered protocol family 17 [    0.952380] NET: Registered protocol family 15 [    0.952546] Bluetooth: RFCOMM socket layer initialized [    0.952615] Bluetooth: RFCOMM ver 1.11 [    0.952640] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [    0.952662] Bluetooth: HIDP socket layer initialized [    0.952719] [BT_RFKILL]: Enter rfkill_rk_init [    0.952722] [WLAN_RFKILL]: Enter rfkill_wlan_init [    0.953596] [WLAN_RFKILL]: Enter rfkill_wlan_probe [    0.953635] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255 [    0.953638] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [    0.953641] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [    0.953672] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 20, flags = 0. [    0.953680] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [    0.953682] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [    0.953687] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [    0.953691] [WLAN_RFKILL]: Exit rfkill_wlan_probe [    0.954258] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77. [    0.954280] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 17. [    0.954290] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 12. [    0.954300] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 11. [    0.954363] [BT_RFKILL]: Request irq for bt wakeup host [    0.954462] [BT_RFKILL]: ** disable irq [    0.954584] [BT_RFKILL]: bt_default device registered. [    0.954682] Key type dns_resolver registered [    0.954947] flash vendor_init_thread! [    0.954950] flash vendor storage:20170308 ret = -1 [    0.956245] Loading compiled-in X.509 certificates [    0.956805] pstore: Using compression: deflate [    0.957674] rga2: Driver loaded successfully ver:3.2.63318 [    0.957989] rga2: Module initialized. [    0.987326] rockchip-drm display-subsystem: defer getting devfreq [    0.987627] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x0, primary plane phy id: -1 [    0.987637] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1 [    0.987645] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1 [    0.987894] [drm] failed to init overlay plane Cluster0-win1 [    0.987931] [drm] failed to init overlay plane Cluster1-win1 [    0.988095] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008ef7890) [    0.988277] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [    0.989173] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [    0.990840] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008efb8b0) [    0.990893] rockchip-drm display-subsystem: bound fe060000.dsi (ops 0xffffff8008efc200) [    0.990903] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [    0.990906] [drm] No driver support for vblank timestamp query. [    0.991042] rockchip-drm display-subsystem: failed to parse loader memory [    0.999125] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1200x1920p60, type: 16 for vp1 [    0.999502] dw-mipi-dsi fe060000.dsi: [drm:dw_mipi_dsi_encoder_enable] final DSI-Link bandwidth: 996 x 4 Mbps [    1.225657] dwmmc_rockchip fe2b0000.dwmmc: Successfully tuned phase to 270 [    1.225702] mmc0: new ultra high speed SDR104 SDHC card at address 0001 [    1.228838] mmcblk0: mmc0:0001 EB1QT 29.8 GiB [    1.235404]  mmcblk0: p1 p2 p3 [    1.751642] Console: switching to colour frame buffer device 150x120 [    1.811379] rockchip-drm display-subsystem: fb0:  frame buffer device [    1.812706] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0 [    1.813214] mali fde60000.gpu: Kernel DDK version g2p0-01eac0 [    1.813329] mali fde60000.gpu: Looking up mali-supply from device tree [    1.813427] mali fde60000.gpu: Linked as a consumer to regulator.8 [    1.813435] mali fde60000.gpu: Looking up shadercores-supply from device tree [    1.813448] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed [    1.813521] mali fde60000.gpu: Looking up mali-supply from device tree [    1.813546] vdd_gpu: could not add device link fde60000.gpu err -17 [    1.813556] vdd_gpu: Failed to create debugfs directory [    1.813567] mali fde60000.gpu: Looking up shadercores-supply from device tree [    1.813577] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed [    1.813596] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19 [    1.813919] mali fde60000.gpu: leakage=8 [    1.814517] mali fde60000.gpu: avs=0 [    1.814533] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [    1.814992] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0 [    1.815109] mali fde60000.gpu: No memory group manager is configured [    1.815688] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0 [    1.816691] mali fde60000.gpu: Probed as mali0 [    1.817975] input: adc-keys as /devices/platform/adc-keys/input/input1 [    1.819188] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    1.819461] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    1.819471] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    1.819504] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    1.819524] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    1.819535] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    1.819565] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    1.819571] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    1.820235] rockchip-dmc dmc: Looking up center-supply from device tree [    1.820332] rockchip-dmc dmc: Linked as a consumer to regulator.7 [    1.820345] of_clk_hw_onecell_get: invalid index 3 [    1.820474] ERROR: could not get clock /dmc:dmc_clk(0) [    1.820575] rockchip-dmc dmc: Cannot get the clk dmc_clk. If using SCMI, trusted firmware need update to V1.01 and above. [    1.820791] rockchip-dmc dmc: Dropping the link to regulator.7 [    1.820817] rockchip-dmc: probe of dmc failed with error -2 [    1.822012] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok [    1.828441] asoc-simple-card rk817-sound: rk817-hifi <-> fe410000.i2s mapping ok [    1.830889] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    1.831099] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    1.831108] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    1.831142] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    1.831163] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    1.831174] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    1.831203] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    1.831209] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    1.833039] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    1.833363] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    1.833374] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    1.833406] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    1.833426] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    1.833437] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    1.833463] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    1.833470] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    1.835652] rockchip_headset rk-headset: Can not read property hook_gpio [    1.835669] rockchip_headset rk-headset: headset have hook adc mode [    1.835875] input: rk-headset as /devices/platform/rk-headset/input/input2 [    1.837019] cfg80211: Loading compiled-in X.509 certificates for regulatory database [    1.838542] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [    1.838648] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [    1.838654] cfg80211: failed to load regulatory.db [    1.839682] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    1.839800] rockchip-pm rockchip-suspend: not set pwm-regulator-config [    1.840026] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    1.840036] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    1.840075] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    1.840095] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    1.840109] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    1.840139] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    1.840145] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    1.840472] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 413; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '23:09:19', on 'Oct  8 2021'. [    1.840905] Mali: [    1.840907] Mali device driver loaded [    1.840918] rkisp rkisp-vir0: clear unready subdev num: 2 [    1.840925] rockchip-csi2-dphy0: No link between dphy and sensor [    1.841423] rockchip-csi2-dphy0: No link between dphy and sensor [    1.841427] rkisp-vir0: update sensor failed [    1.841720] ALSA device list: [    1.841723]   #0: rockchip,hdmi [    1.841726]   #1: rockchip,rk817-codec [    1.842171] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [    1.842457] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [    1.842466] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [    1.842502] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [    1.842521] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply from device tree [    1.842533] dwmmc_rockchip fe2c0000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe2c0000 failed [    1.842561] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply from device tree [    1.842567] dwmmc_rockchip fe2c0000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe2c0000 failed [    1.848350] EXT4-fs (mmcblk0p3): mounted filesystem without journal. Opts: (null) [    1.848401] VFS: Mounted root (ext4 filesystem) readonly on device 179:3. [    1.849263] devtmpfs: mounted [    1.852209] Freeing unused kernel memory: 1600K [    1.872223] Run /sbin/init as init process [    1.919710] devfreq fde60000.gpu: Couldn't update frequency transition information. [    1.992164] headset_interrupt:get pin level again, pin=148,i=0 [    1.992309] (headset in is low level)headset status is in [    2.165622] phy phy-fe8a0000.usb2-phy.1: charger = USB_DCP_CHARGER [    2.371172] udevd[193]: starting eudev-3.2.10 [    3.049589] EXT4-fs (mmcblk0p3): Remounting file system with no journal so ignoring journalled data option [    3.051804] EXT4-fs (mmcblk0p3): re-mounted. Opts: data=writeback,errors=remount-ro [    3.181336] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
donation   irradium
Working
  •     LAN
  •     USB2
  •     HDMI
slarm64-current-aarch64-server-quartz64-4.19.210-build-20211010.img.zst
slarm64-current-aarch64-server-quartz64-4.19.210-build-20211010.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-4.19.210-build-20211010.img.zst
slarm64-current-aarch64-xfce-quartz64-4.19.210-build-20211010.img.zst.sha256
donation   irradium
(10-10-2021, 01:45 PM)mara Wrote: Working
  •     LAN
  •     USB2
  •     HDMI
I tried the "xfce-quartz64-4.19.210" one on both MicroSD card and eMMC module, but I couldn't get them to finish booting.
However the "server-quartz64-4.19.210" one works very nicely on a MicroSD card. The only comment I have is that "reboot" doesn't work. I had to either chop the power or long press the power button to get it back.
Anyway I want to give you a massive thanks for doing this because I managed to adapt your image to boot on a noname tablet that I bought and I can now boot your slackware image from the microSD card of that. This is a big win for me. Thanks!
(11-13-2021, 12:56 PM)dieselnutjob Wrote: I tried the "xfce-quartz64-4.19.210" one on both MicroSD card and eMMC module, but I couldn't get them to finish booting.
xfce image is built similarly to the server, should it work the same, and is there a jumper on the battery contacts?
I checked the хfce image is loaded fine. The only thing after the first reboot is to physically remove the power supply (not with a button), in this bootloader any reboot will get stuck on the bootloader.
donation   irradium
can I dd your xfce image straight to an eMMC card?
(11-13-2021, 04:19 PM)dieselnutjob Wrote: can I dd your xfce image straight to an eMMC card?
anyway, you just need to change the name of the root partition in /etc/fstab and /boot/uEnv.txt
donation   irradium
  USB on Quartz64 Zero litbulb 2 3,055 11-09-2026, 01:33 PM
Last Post: elizabethtaylor
  DietPi OS for Quartz64 MichaIng 48 65,193 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,136 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,731 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 194,557 03-23-2025, 01:10 AM
Last Post: balbes150
  quartz64-a - on-board SATA port problems manning 2 6,233 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,018 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,784 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,394 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 60,735 03-17-2022, 06:29 AM
