GDM3 Receiving call on login screen
Hello from a new and happy Canadian owner of a Pinephone.
I'm really impressed so far and I tried some distros. My choice is now Mobian and I installed Gnome Shell. I tried to find the answer to my question with no luck therefore, I'm asking in here.
Is there a way to answer a phone call from the login screen without having to actually log in user session? I really dont have the time to login with the password when the phone rings and, I miss the call. In GDM3.
Thank you all and long live to Pinephone!
(10-07-2021, 11:04 AM)d-.-b Wrote: Hello from a new and happy Canadian owner of a Pinephone.
Are you using a recent Mobian release ?
My phone has been giving me the option to 'answer'  incoming calls while the screen is 'locked' for quite a while now.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I am using this one: mobian-pinephone-phosh-20210517.img and I ran from command line the instructions here: https://wiki.mobian-project.org/doku.php...vironments I thought it was the more "stable" version available (im totally noob). So I guess I should get a newer version (from https://images.mobian-project.org/pinephone/nightly/) and give it a try? I will try on SD card (so noob that I did not even thought about trying a new release but, that is how you learn..)
Thank you
... perhaps installing the Gnome shell had an effect on this ? ... ( just a guess)
Am curious are you running from eMMC or an sd card ?
Welcome to the Forum, Good Luck with your New Pine phone.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(10-07-2021, 05:27 PM)bcnaz Wrote: ... perhaps installing the Gnome shell had an effect on this ?  ...  ( just a guess)
I am running from eMMC. I tried a newer Mobian image on SD card and it worked once. After that, I always had to enter password and login to answer. I got back to Phosh as it does works perfectly fine for my needs. I might get back to Gnome Shell later on tho, the journey just begun.
Thank you for your help.
  How to add an homemade app to the main screen? JChdeL 3 427 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 1,870 07-18-2025, 07:56 PM
  On-Screen Keyboard Arrow Keys biketool 10 5,509 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,036 01-15-2025, 08:08 PM
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 3,681 12-01-2024, 07:54 PM
Last Post: dchang0
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,668 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 1,786 12-26-2023, 06:08 AM
Last Post: mdk
  Auto start application on Phosh login Zebulon Walton 8 9,134 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Screen stay black unless power key pressed short freelectro 0 1,875 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 13,471 06-22-2023, 11:20 AM
Last Post: Melechtna
