Plasma Mobile - How supposed to change screen brightness?
When booting up with Plasma Mobile, the screen brightness is set to minimum.
Looking at the action menu at the top, I can find two icons which look like any other ions of suns indicating brightness. In this case there is no slider, and pressing on the icons does nothing.
Any ideas?
> > Screen brightness is in settings under Power.
Of the Distro's I have tried myself, I have not yet seen one with a shortcut on the top drop down menu.
BUT it may be on their roadmap for the future.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
There is no menu "Power" in the settings in Plasma Mobile I can find.
Manjaro/Plasma ?
I don't have that OS in any of my phones at the moment, guess I can flash an sd card and look again.
Seems I remember the settings menu 'was' the same as Mobians.
It has been a while, so I guess it could be interesting to look at Manjaro again.
I'll take a look and get back to here.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
So I have Manjaro Plasma on a sd card running on a PMOS Convergent phone now...
Sure has lots of eye candy !   Big Grin
But lots of stuff appears to not work ?
  I did make a few outgoing calls, and incoming.
..*  and now it says modem is NOT connected !  >(the icon at the top shows connected & strong signal ? )
..... but it will make a call ?
  Text will randomly send after hitting send repeatedly,
Thinking updates might help, I am attempting to do updates... It shows a whole page of updates.
It did do updates but it was just a black screen with no progress indicators.
I cannot find any Brightness settings ether.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
There is an "Energy" setting, but that is for screen dim and lock. I think best to do updates in SSH. I have noticed many distros will fail in the GUI.
I also have the Manjaro Phosh on the eMMC card , and I the modem will shut down after booting, and unlocking the screen.
(10-06-2021, 06:50 PM)KNERD Wrote: There is an "Energy" setting, but that is for screen dim and lock. I think best to do updates in SSH. I have noticed many distros will fail in the GUI.
....  yesterday when I tried Plasma,  it said no modem detected,  * but it still made and received calls and did 2 way texts  ? ? Huh
        I tried multiple separate times to put in my APN information,  * but it kept  reverting to it's original settings.
The appearance is quite impressive,  ... but function, not so much....   (actually disappointing and frustrating)
* Curious :  Why did they do NOT include screen brightness in the "Settings" ?   *<(Perhaps it needs it own separate App.?)>
 ***  I would think "Seeing the screen" should certainly be a Priority item.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Again - I don't understand what are you doing there Big Grin
Screen brightness slider is in the screen top side pulldown menu - at first there will be shown row with 5 icons and below them a little arrow (+ notifications window), pulling that arrow down there will be other top menu icons and screen brightness slider Wink
Running beta7+updates here Smile
(10-07-2021, 10:54 PM)acrux Wrote: Again - I don't understand what are you doing there Big Grin
[Image: JClYDZ7.jpg]
So, where is that slider?
[Image: PoOOUAb.jpeg]
Here Big Grin
As said - Manjaro-ARM-plasma-mobile-pinephone-beta7.img + updates. Also using Breeze Dark theme, colors etc everywhere.
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 2,746 07-03-2024, 08:38 PM
  screen brightness Uturn 1 3,253 10-09-2023, 04:38 AM
Last Post: Eugo
  what is wrong with KDE plasma beta15 RC4? Uturn 8 7,705 10-02-2023, 05:07 AM
Last Post: Uturn
  screen brightness locked Uturn 0 2,524 07-07-2023, 09:38 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 13,093 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,109 02-24-2023, 12:56 PM
Last Post: jakfish
  gnome-mobile dev Uturn 1 2,698 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 13,312 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 3,813 11-22-2022, 05:00 PM
Last Post: Chief
  Screen timeout makes alarm and timer unusable... Eugo 9 9,555 10-03-2022, 01:41 AM
Last Post: Eugo
