04-29-2016, 01:25 AM
A BBQ prob base. 8 probes and eventually several remote probes and draft controllers. With cloud database and UI.
What will you be using your PINE64 for?
04-29-2016, 04:06 AM
I'll probably look it for a long while as I have no idea how to get it going. But that does not mean I won't learn with the help of someone.
I bought a 1 GB (I think) with b/t w/f and Z wave All in the acrylic case. My aim was to get Z wave going but again I am not sure where to start. If someone would like to give an absolute beginner some starting tips I would really appreciate it. Thanks Mick
04-29-2016, 05:29 PM
After playing with the Linux distro and checking performance of the audio I/O ports, I'm going to try and get some bare metal code loading on the thing, then possibly start a port of FreeRTOS to the board. That could be quite the cool thing!
04-30-2016, 04:44 PM
I'm using one of my pines as a pine64 community IRC server (in sig). The other is reserved for experimenting. So far I have tried all the different Linux distros - I'm currently on Debian - and RemixOS. I am still to try the Android img. I may just end up setting my second Pine64 up as a web server and torrent box (to help out my fav distros / Pine64 imgs).
05-22-2016, 04:24 AM
My first goal will be connecting it to a MIDI sprout
https://www.kickstarter.com/projects/dat...ion-device and record MIDI.
05-23-2016, 08:52 AM
Using it as a paper weight.
05-23-2016, 09:19 AM
05-23-2016, 10:16 AM
I'm hoping to be able to use them for PCAP. Currently we use micro Ubuntu PC's. I have a few other things in mind, but I'm hoping they have enough grunt to pull this off.
I'm also planning to use one for a desktop if it gets enough performance. I rarely use my gaming PC for gaming anymore.. Figure it's a bit of a power sink for what little web surfing I do. RemixOS should give me everything I need in that respect.
I have 4 spare 1U cases, I bought a temperature sensor board to control the fans and will mount my 6 1GB boards in there, with a 16 port gigabit router and with room for 9 more Pine64 later. I will then put a minimal Linux OS on my boards. Then add a Python 2.7 environment. That is all I need to then distribute my Machine Learning routines across all 6 boards supporting ensemble learning. If successful I'll expand to 15 boards, giving me 60 cores to play with. A GPU might be more powerful for the matrix manipulations, but involves extra code and more heat.
External storage problem for pine64 | Dani6102 | 3 | 6,721 |
07-26-2023, 10:57 AM Last Post: tophneal |
| Pine64 as wireless audio device | S265 | 3 | 8,868 |
04-07-2022, 10:39 PM Last Post: S265 |
| Pine64(+) and manjaro | dsychan | 0 | 4,299 |
04-05-2022, 11:32 PM Last Post: dsychan |
Pine64 was a Useless Project | pushpendrak | 18 | 43,586 |
11-21-2020, 10:17 PM Last Post: tllim |
| Pine64 LCD | rstcologne | 0 | 5,397 |
09-22-2020, 12:43 PM Last Post: rstcologne |
| Pine64+ power button | PaddyChan | 0 | 5,220 |
09-14-2020, 09:55 AM Last Post: PaddyChan |
| Pine64 OS | dpcons | 2 | 7,563 |
03-02-2020, 04:32 PM Last Post: dpcons |
| Jailhouse supports Pine64+ | vj-kumar | 0 | 5,661 |
02-17-2020, 11:39 PM Last Post: vj-kumar |
| PINE64 board not powering up | loki21century | 2 | 8,732 |
11-25-2019, 12:19 PM Last Post: Partymack711 |
| Pine64 not powering up. | skylab | 5 | 12,521 |
05-03-2019, 02:48 PM Last Post: Mendota |
